Getting ready to start, but need to move the car sideways... |
Mike Pearson |
Aug 16 2003, 06:50 PM
I *am * in shape; ROUND is a shape! Group: Members Posts: 29 Joined: 2-July 03 From: Seattle, WA Member No.: 876 |
OK, I'm about ready to move the car over to where I can actually drop the engine/tranny and start work on it, but it's been sitting in the same spot for 7 years now. The rear wheels have sunk into the mud a bit (not too bad...just created a little trough). I put it up on a jack and made sure the rears turn (the brakes aren't locked/frozen). Unfortunately, where it's sitting is on a little uphill section. I need to turn it 90 degrees. The easiest way, where it's sitting, would be to pick up the front end and walk it over about 8 feet. Yeah, right...I don't think *that* going to happen...we have maybe 3 people that can help.
I was looking, and we have a large Douglas fir tree. I was thinking that we may be able to tie a tow strap to the front A-arm, pass it around the tree, and use the Subaru Outback to pull the front end around. This would be moving it in an arc, turning the car about 45 degrees to where we could actually push it to roll it into place. If the engine hadn't gotten water into it I would just use the starter motor to help move it, but it's in a rather tight spot. How much (potential) damage would we do by dragging the front end sideways through the dirt? Any other ideas? We tried pushing it earlier, but the bumper on the Outback doesn't line up right, and we'd wind up doing all sorts of front-end damage to it if we tried to push the 'teener. Lots of smart folks on this board...any ideas on how to turn a teener 90 degrees with the minimum of fuss and damage? Thanks! |
Mike Pearson |
Aug 18 2003, 11:54 PM
QUOTE(rhodyguy @ Aug 17 2003, 07:18 PM) get cheap plywood. 5/8 cdx if it will be in ground contact for a while. bet it takes 3 sheets. that gives you 8'x12'. double up where the floor jack will run. prob have to "walk" it around. borrow or buy a second floor jack so you don't have to drag the jack back and forth. kevin Thanks, Kevin. We have some plywood that was left over from last year's roofing project, two floor jacks, the come-along, and 3 of us working on it, so we should be able to make it happen next Sunday. |
Lo-Fi Version | Time is now: 1st June 2024 - 08:34 AM |
