> Cooler air in cylinders equals more, P O W E R
gregrobbins
post Nov 13 2005, 11:41 PM
Member: Team NARP
At the DE today at Firebird Raceway, there was one very quick 2.0L 914.
I met and talked with the owner John Seymour for awhile. One of the innovations he came up with really looks interesting. Instead of the stock air filter box. he looked for a way to get cooler air into the motor. Study the photo (I have more if you want me to post). He ran a PVC pipe from the TPS to hoses that go down to the J tubes. From there they are connected to the air ducts in the longs and finally, he is pulling air from the opening in front of the windshield. He claims it works like a charm. I don't doubt him, as he is running D-jet and was as quick or quicker than the 2.0L cars that had been converted to carbs.
Jake Raby
post Nov 14 2005, 09:34 AM
Engine Surgeon
Cooler air makes more power, no matter the engine- as long as enrichment is correct for the given air temperature..
Look at all newer cars, they have fresh air intakes from the front of the vehicle- thats why, the engine bay gets hot and hot air doesn't make power.
This is also the reason I have fresh air intakes into my dyno just for the carbs/ Throttle bodies.
gregrobbins   Cooler air in cylinders equals more   Nov 13 2005, 11:41 PM
bd1308   its cool if you dont need heat. i give him props...   Nov 13 2005, 11:45 PM
gregrobbins   Oh yea, the car is listed for sale on the AZ Regio...   Nov 13 2005, 11:48 PM
gregrobbins   One more. Notice the venting for the oil cooler in...   Nov 13 2005, 11:49 PM
bd1308   a bumblebee? http://www.914world....   Nov 13 2005, 11:51 PM
gregrobbins   Yep, a Bumble Bee. VIN fall right in the middle of...   Nov 14 2005, 12:05 AM
Hammy   I'm a bit confused as to how the air goes to t...   Nov 14 2005, 12:49 AM
Brando   Now if he put a little scoop over the front air ve...   Nov 14 2005, 12:52 AM
bd1308     Nov 14 2005, 01:30 AM
jkeyzer   Does that actually work or is all the piping a res...   Nov 14 2005, 02:33 AM
Andyrew   I agree, probably negligable. You want cold air? ...   Nov 14 2005, 02:47 AM
gregrobbins   Does it work? He says he is running a stock fi 2.0...   Nov 14 2005, 08:38 AM
Jake Raby   Cooler air makes more power, no matter the engine-...   Nov 14 2005, 09:34 AM
dmenche914   No provision for an air filter is seen. In my opi...   Nov 14 2005, 10:14 AM
URY914   There is no doubt that cooler air can make more po...   Nov 14 2005, 10:28 AM
Jake Raby   It doesn't look like it has very much volume t...   Nov 14 2005, 11:27 AM
Racer Chris   The fresh air box ahead of the windshield sees hig...   Nov 14 2005, 11:49 AM
Rand     Nov 14 2005, 04:40 PM
jsteele22   Most of the time an intercooler is used in a turbo...   Nov 14 2005, 04:42 PM
scotty b   flow rate could easily be increased with two of th...   Nov 14 2005, 06:28 PM
Andyrew   Heres my response to your PM srbliss I couldnt get...   Nov 14 2005, 06:39 PM
ein 6er   hey ........ why not run hoses to your ac vents an...   Nov 14 2005, 07:22 PM
jsteele22   ...   Nov 14 2005, 07:26 PM
Dave_Darling   ...   Nov 14 2005, 07:28 PM
Eric_Shea   I think you neighbor's alredy got a patent on ...   Nov 14 2005, 08:33 PM
- Lo-Fi Version Time is now: 4th July 2025 - 04:46 PM
