> Cooler air in cylinders equals more, P O W E R
gregrobbins
post Nov 13 2005, 11:41 PM
Member: Team NARP
At the DE today at Firebird Raceway, there was one very quick 2.0L 914.
I met and talked with the owner John Seymour for awhile. One of the innovations he came up with really looks interesting. Instead of the stock air filter box. he looked for a way to get cooler air into the motor. Study the photo (I have more if you want me to post). He ran a PVC pipe from the TPS to hoses that go down to the J tubes. From there they are connected to the air ducts in the longs and finally, he is pulling air from the opening in front of the windshield. He claims it works like a charm. I don't doubt him, as he is running D-jet and was as quick or quicker than the 2.0L cars that had been converted to carbs.
jsteele22
post Nov 14 2005, 07:26 PM
QUOTE (scotty b @ Nov 14 2005, 05:28 PM)
flow rate could easily be increased with two of the aftermarket blowers made for vw heating systems. Put one on each side, towards the rear so it would pull from the front and give a little boost just before the intake. I've thought about it befor but I was thinking of running it through the firewall and then through the center tunnel. Pvc in the tunnel, flex pipe at the walls.
That's really just a supercharger, but powered indirectly (and inefficiently) via alternator/wires/motor instead of a belt. If the fan motor is wimpy (like a VW heater blower) you aren't really gaining anything noticeable in terms of power. If it's not, you are placing a huge load on the car's engine (and alternator). In general, a supercharger is less efficient than a turbo, b/c it takes "good" energy to drive it (from the crankshaft) as opposed to "bad" energy (from the exhaust stream). So says Corky Bell, anyways.
The problem with this kind of thing, is that to get any significant increase in power, you have to increase the number of O2 molecules significantly. Just wafting them along through a tube won't cram many more of them into the cylinder. To get a feel for it, imagine using a bicycle pump to pump a car tire from 0 psi (gauge) to 10 psi (gauge). It's no manliness contest, but it does take a little time and effort. Compare this to a decent turbo setup which runs at 10 psi of boost. Since atmospheric pressure (for you lowlanders) is about 15 psi, that means an increase of around (25/15 -1) or 65% in oxygen going into the engine. So, ignoring lots of details, you get around 65% more power. Now for a 2.0L engine at 3600 RPM you breathe (3600/2 /60 * 2.0L) or 60 liters of air per second. Thats about 16 gallons of air. I don't know the volume of a car tire, but it seems rather less than 16 gallons. And 3600 RPM is kind of timid. But just imagine having to pump that tire up to 10 psi once per second, and you get a feel for the kind of job a turbocharger (or supercharger) has to accomplish. If you try something that's wimpy compared to a turbo/super charger, you'll get a result that's wimpy as well.
Using cool air, though modest, does help. It's like letting nature take care of all the hard work ahead of time. Working in absolute (Kelvin) degrees, density is proportional to temperature, if pressure is held constant (like atmospheric, fer example). So going from 55 C down to 35 C (i.e., 131 F down to 95 F), which is a 20 degree diff at (273 + 35) K, gives an increase in O2 (hence HP) of 6% without expending any effort.
gregrobbins   Cooler air in cylinders equals more   Nov 13 2005, 11:41 PM
bd1308   its cool if you dont need heat. i give him props...   Nov 13 2005, 11:45 PM
gregrobbins   Oh yea, the car is listed for sale on the AZ Regio...   Nov 13 2005, 11:48 PM
gregrobbins   One more. Notice the venting for the oil cooler in...   Nov 13 2005, 11:49 PM
bd1308   a bumblebee? http://www.914world....   Nov 13 2005, 11:51 PM
gregrobbins   Yep, a Bumble Bee. VIN fall right in the middle of...   Nov 14 2005, 12:05 AM
Hammy   I'm a bit confused as to how the air goes to t...   Nov 14 2005, 12:49 AM
Brando   Now if he put a little scoop over the front air ve...   Nov 14 2005, 12:52 AM
bd1308     Nov 14 2005, 01:30 AM
jkeyzer   Does that actually work or is all the piping a res...   Nov 14 2005, 02:33 AM
Andyrew   I agree, probably negligable. You want cold air? ...   Nov 14 2005, 02:47 AM
gregrobbins   Does it work? He says he is running a stock fi 2.0...   Nov 14 2005, 08:38 AM
Jake Raby   Cooler air makes more power, no matter the engine-...   Nov 14 2005, 09:34 AM
dmenche914   No provision for an air filter is seen. In my opi...   Nov 14 2005, 10:14 AM
URY914   There is no doubt that cooler air can make more po...   Nov 14 2005, 10:28 AM
Jake Raby   It doesn't look like it has very much volume t...   Nov 14 2005, 11:27 AM
Racer Chris   The fresh air box ahead of the windshield sees hig...   Nov 14 2005, 11:49 AM
Rand     Nov 14 2005, 04:40 PM
jsteele22   Most of the time an intercooler is used in a turbo...   Nov 14 2005, 04:42 PM
scotty b   flow rate could easily be increased with two of th...   Nov 14 2005, 06:28 PM
Andyrew   Heres my response to your PM srbliss I couldnt get...   Nov 14 2005, 06:39 PM
ein 6er   hey ........ why not run hoses to your ac vents an...   Nov 14 2005, 07:22 PM
jsteele22   ...   Nov 14 2005, 07:26 PM
Dave_Darling   ...   Nov 14 2005, 07:28 PM
Eric_Shea   I think you neighbor's alredy got a patent on ...   Nov 14 2005, 08:33 PM
- Lo-Fi Version Time is now: 4th July 2025 - 07:20 AM
