What's your compression ratio? |
porsche735 |
Aug 20 2003, 12:06 PM
Member Group: Members Posts: 189 Joined: 10-January 03 From: Los Altos, CA Member No.: 127 |
I am rebuilding my 2.0L....again and want to know what folks are running for compression ratios. What compression tester readings are you getting at first rebuild and then once the engine has "settled"? How long did the engine take to "settle"?
The reason for our rebuild is: cyl #1 110lbs cyl #2 115lbs cyl #3 110lbs cyl #4 45lbs Thanks, Chris |
Brad Roberts |
Aug 20 2003, 12:08 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
New engines:
100 around the corners. After 500 miles and warm: 120 around the corners. What happened this time ?? And did it just happen at ThunderHill ?? What kind of oil temps are you seeing now with the cooler ?? B |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:06 PM |
