What's your compression ratio? |
porsche735 |
Aug 20 2003, 12:06 PM
Member Group: Members Posts: 189 Joined: 10-January 03 From: Los Altos, CA Member No.: 127 |
I am rebuilding my 2.0L....again and want to know what folks are running for compression ratios. What compression tester readings are you getting at first rebuild and then once the engine has "settled"? How long did the engine take to "settle"?
The reason for our rebuild is: cyl #1 110lbs cyl #2 115lbs cyl #3 110lbs cyl #4 45lbs Thanks, Chris |
porsche735 |
Aug 20 2003, 12:31 PM
I am starting to think it is the spark plug wires. We replaced them 2 years ago, but it seems like that may be the only thing left that could be causing our problems.
What do you run for wires? Magnecor? Our's currently, are Bosch. Chris |
Lo-Fi Version | Time is now: 3rd June 2024 - 02:28 AM |
