What's your compression ratio? |
porsche735 |
Aug 20 2003, 12:06 PM
Member Group: Members Posts: 189 Joined: 10-January 03 From: Los Altos, CA Member No.: 127 |
I am rebuilding my 2.0L....again and want to know what folks are running for compression ratios. What compression tester readings are you getting at first rebuild and then once the engine has "settled"? How long did the engine take to "settle"?
The reason for our rebuild is: cyl #1 110lbs cyl #2 115lbs cyl #3 110lbs cyl #4 45lbs Thanks, Chris |
SirAndy |
Aug 20 2003, 12:47 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(porsche735 @ Aug 20 2003, 11:28 AM) Oil temps have been good <275 sometimes with 2 drivers going. Mostly around 250. oil temps are too high, you should stay under 250 for sure, 200 would be much better ... Andy |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:45 PM |
