Wiring hell, stumped-long. |
Hammy |
Nov 22 2005, 06:40 PM
mr. Wonderful Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California |
I'm having a lot more trouble with my lights than I thought I would.
First off, PO had the car wired so that the fogs would only turn on with brights. I see no point in that, but that's how it was wired. They had a black wire w/ blue stripe coming out from under the dash wiring harness area plugged into the #3 fuse. I think this black wire with blue stripe was supposed to go onto the fog light switch? There were only 2 wires plugged into the fog light switch when I found it. I tried to do the fog light rewiring that required cutting a few wires, and piggybacking a few. I failed to get that to work. So I bought a fog light flash kit and it's well made. I have it all wired up, and the fog lights were working with the ignition just like they're supposed to and would flash when I pulled the stalk back. My headlights would open up, but the headlights would NOT turn on, but parking lights would. I turned the turn signal lever down to see if the signals would work and I lost my dash lights, and fog lights. I know this has nothing to do with the fog light flasher kit, I'm not flaming on that. It's got to be the PO's wiring. I'm frusterated as hell. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) First off, what's supposed to go into the #3 fuse closest to the seat? |
markb |
Nov 22 2005, 06:45 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
You've gone to Pelican & gotten their wiring diagrams, right? All I can say is start tracing down the wiring. Fix what the PO did before you start adding things, or you'll just get confused.
Don't feel bad, I'm still tracking down gremlins in the 71. Sometimes it seems it will never end. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:14 PM |
