Wiring hell, stumped-long. |
Hammy |
Nov 22 2005, 06:40 PM
mr. Wonderful Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California |
I'm having a lot more trouble with my lights than I thought I would.
First off, PO had the car wired so that the fogs would only turn on with brights. I see no point in that, but that's how it was wired. They had a black wire w/ blue stripe coming out from under the dash wiring harness area plugged into the #3 fuse. I think this black wire with blue stripe was supposed to go onto the fog light switch? There were only 2 wires plugged into the fog light switch when I found it. I tried to do the fog light rewiring that required cutting a few wires, and piggybacking a few. I failed to get that to work. So I bought a fog light flash kit and it's well made. I have it all wired up, and the fog lights were working with the ignition just like they're supposed to and would flash when I pulled the stalk back. My headlights would open up, but the headlights would NOT turn on, but parking lights would. I turned the turn signal lever down to see if the signals would work and I lost my dash lights, and fog lights. I know this has nothing to do with the fog light flasher kit, I'm not flaming on that. It's got to be the PO's wiring. I'm frusterated as hell. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) First off, what's supposed to go into the #3 fuse closest to the seat? |
SGB |
Nov 22 2005, 08:09 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
I'm not studying diagrams either, but I know that the headlights are individually fused (fuse 1&2 are low beam, 3&4 are high beam) so if BOTH are not illuminated, it indicates that the flasher relay isn't wired right- and that is where the fog-flasher integrates. I don't know how the PP kit works really. I wired my own several years ago using 2 relays, not the kit, but I do recall that the only common source for both HL is at the flasher relay.
Lo-Fi Version | Time is now: 2nd June 2024 - 11:30 AM |
