> Taking the crank down to bare bones, swapping bearings
DNHunt
post Nov 23 2005, 01:28 PM
914 Wizard? No way. I got too much to learn.
Time to get this thing done so, here's how I pulled the gears on the crank and replaced the #3 main bearing.
First I drilled a countersink into the top of an 8 mm bolt to protect the threads in the nose of the crank thtat secures the fan hub.
Carrera916
post Nov 23 2005, 04:38 PM
wow!
KUDOS to these guys for sharing the info with us! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
I'm curious to know what got your attention to stop and strip the engine down? The sound of scrapping in the piston/cylinder areas while running or was it smoking badly when you ran it due to bad oil rings?
I figured it would be the smoke part but do tell us anyhow!
Hope this time would work out better for you, Dave!
Jerry
DNHunt   Taking the crank down to bare bones   Nov 23 2005, 01:28 PM
DNHunt   I threaded that bolt into the nose of the crank th...   Nov 23 2005, 01:30 PM
DNHunt   You end up with a bare crankshaft that you can get...   Nov 23 2005, 01:34 PM
DNHunt   You end up with these bits   Nov 23 2005, 01:35 PM
DNHunt   Clean and lube up the journal and put the bearing ...   Nov 23 2005, 01:39 PM
DNHunt   Heat up the gears to expand them. I got away with ...   Nov 23 2005, 01:45 PM
Headrage   I used a toaster oven for my gears. Once they are...   Nov 23 2005, 01:48 PM
DNHunt   Drop the gear on, line up the slot with the Woodru...   Nov 23 2005, 01:48 PM
DNHunt   Next comes a spacer with the VW logo.   Nov 23 2005, 01:50 PM
DNHunt   Next comes the dizzy drive gear. Line it up with t...   Nov 23 2005, 01:52 PM
DNHunt   Here's my persuader. I love PVC pipe. I have a...   Nov 23 2005, 01:58 PM
DNHunt   Lastly, there is a retaining ring which can be a b...   Nov 23 2005, 01:59 PM
maf914   Dave, What are you building now? Didn't you ...   Nov 23 2005, 02:38 PM
thesey914   Dave is this another teardown of your four? I thou...   Nov 23 2005, 02:41 PM
Mark Henry   yeh...what he said http://www.91...   Nov 23 2005, 02:54 PM
Jake Raby   Dave has involuntarily been a guinea pig for Charl...   Nov 23 2005, 02:57 PM
DNHunt   This is the same engine. I had the same problems t...   Nov 23 2005, 03:35 PM
davep   Bravo, and the best of luck this time around.   Nov 23 2005, 04:10 PM
Carrera916   wow! KUDOS to these guys for sharing the info...   Nov 23 2005, 04:38 PM
thesey914   I'm just waiting for JP or Trek to chime ...   Nov 23 2005, 04:56 PM
Jake Raby   The cam is another interesting thing... I haveb us...   Nov 23 2005, 05:07 PM
rhodyguy   a 5hp loss on dave's engine will be undetectab...   Nov 25 2005, 11:10 AM
davep   h...   Nov 25 2005, 01:11 PM
- Lo-Fi Version Time is now: 11th July 2025 - 01:05 PM
