> Toe Curve for Semi-trailing arm, From my 914
groot
post Nov 14 2005, 02:36 PM
Dis member
Some of us have been discussing the 914 rear suspension offline and I measured my toe curve yesterday. I figured I'd share it with the club for discussion.
The axle height scale is in inches and the zero is with the arm level.
Brett W
post Nov 27 2005, 11:13 AM
I agree seperate them so that they aer more easily read and a 2D curve will suffice for each one.
Yes you will not see large changes in either, because that just doesn't happen. The semi trailing arm does not make big changes, but the little changes will make all kinds of problems in a race situation. When your suspension travel is limited to 1-2 inches in both bump and droop, small variations will become big problems. When your chassis is setup to take advantage of 20K lb/degree of twist, and your suspension is setup so that there is no uncontrolled movement, any suspension movement that is not controlled keeps you out of the winners circle. When your chassis is so stiff that your race car setup changes each time you change tires you know you have done it right.
groot   Toe Curve for Semi-trailing arm   Nov 14 2005, 02:36 PM
MattR   http://www.914world.com/bbs2/...   Nov 14 2005, 02:45 PM
lapuwali   I presume on that graph positive numbers are for b...   Nov 14 2005, 03:07 PM
groot   Sorry, I meant to explain more, but I had to run o...   Nov 14 2005, 03:23 PM
Racer Chris   Based on the graph it appears that your car has th...   Nov 14 2005, 10:08 PM
groot   No inference required... it's right there on t...   Nov 15 2005, 08:40 AM
Racer Chris     Nov 15 2005, 05:04 PM
Brett W   You will increase the scrub by changing the pivot ...   Nov 15 2005, 07:50 PM
brant   wow... great thread Kevin! I'm going to ha...   Nov 15 2005, 11:30 PM
Racer Chris   <...   Nov 16 2005, 07:09 AM
groot   I met with Finch the other day for a few hours and...   Nov 16 2005, 08:26 AM
Racer Chris     Nov 16 2005, 09:01 AM
groot   Good point!! Let's hope there are no ...   Nov 16 2005, 09:11 AM
groot     Nov 16 2005, 09:28 AM
Brett W     Nov 16 2005, 09:29 AM
groot     Nov 16 2005, 10:17 AM
Brett W   http://www.914world.com/bbs2/...   Nov 16 2005, 04:19 PM
Racer Chris     Nov 16 2005, 07:16 PM
Thorshammer   Now this is what I am talking about. Finches car (...   Nov 16 2005, 07:23 PM
Brett W   If you are building a competetive EP car you shoul...   Nov 16 2005, 08:08 PM
Racer Chris   <...   Nov 18 2005, 06:09 AM
Jeroen   this pic claims that the angle of the pivot is 25d...   Nov 18 2005, 06:09 AM
Racer Chris     Nov 18 2005, 06:13 AM
Jeroen   hmmm... looks like your right just did a crude mea...   Nov 18 2005, 06:21 AM
Brett W   The factory angle is 12 degrees. In my research i...   Nov 18 2005, 08:37 AM
MattR   <...   Nov 18 2005, 12:24 PM
MattR   It has nothing to do with orientation and everythi...   Nov 18 2005, 12:49 PM
Thorshammer   This is a good site to understand what is happenin...   Nov 18 2005, 05:19 PM
jhadler   Can you try that link again? It doesn't work.....   Nov 18 2005, 05:25 PM
Brett W   Its kinda on hold until I find some more shop spac...   Nov 18 2005, 08:06 PM
Racer Chris   <...   Nov 18 2005, 08:12 PM
Racer Chris
  Nov 19 2005, 12:04 AM
Racer Chris   If you plot toe or camber as a function of rotatio...   Nov 19 2005, 05:56 AM
Racer Chris   The pivot axis isn't parallel to the direction...   Nov 19 2005, 08:21 AM
groot   Here's an interesting article... that contradi...   Nov 19 2005, 09:12 AM
groot   Eric.... yes, I'm finally on my home computer ...   Nov 19 2005, 09:15 AM
groot   Pretty charts   Nov 19 2005, 09:16 AM
groot   Bigger than I expected... sorry.   Nov 19 2005, 09:17 AM
groot   Last purdy chart   Nov 19 2005, 09:17 AM
Jeroen   kevin, if you e-mail me the .doc file you tried to...   Nov 19 2005, 10:34 AM
groot   Or I could just post the text.... duh.... Car Sus...   Nov 19 2005, 10:51 AM
Brett W   That is some impressive math and I am sure the res...   Nov 26 2005, 08:55 PM
Racer Chris   I don't understand what the 3d surface plots r...   Nov 27 2005, 07:44 AM
Brett W   I agree seperate them so that they aer more easily...   Nov 27 2005, 11:13 AM
Racer Chris   Whats the x axis represent? Can't you convert ...   Dec 5 2005, 08:30 AM
- Lo-Fi Version Time is now: 9th June 2024 - 01:30 AM
