billd |
Member ![]() ![]() Group: Members Posts: 327 Joined: 25-May 05 From: Palo Alto, CA Member No.: 4,145 ![]() |
I'm switching out my torsion bars. The left one slid right out after I took the bolt and adjusting lever off. The right one on the other hand won't budge. I've pulled on it at the rear by hand and with vice grips. I've removed the front valence and guard clip, but can't find a way to get the cover off to drive it out from the front. Any advice?
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
you can drill a small hole in the cover and use a drift to punch out the torsion bar........close up hole with silicon, weld or even a screw.....worse case, hit the torsion bar torwards the front of the car, it'll pop off the metal cover which you'll have to re-install......
Lo-Fi Version | Time is now: 17th June 2024 - 09:52 AM |
