> Installing poly A-Arm Bushings, Is there an easy way?
billd
post Dec 2 2005, 12:00 PM
Any tips on how to install plastic A-arm bushings. They seem to be an extremely tight fit. Do I need to press/pound them on?
Grngoat
post Dec 2 2005, 04:58 PM
Lurker Member
I believe that is probably true. The weltmeisters that were in my car were very tight. With the car on a lift and the top strut bolt removed, you could hang on the A-arm and it would barely budge. But they aren't polyurathane either. I have poly bushings in my GTO, and they are fine. The weltmeisters are a hard plastic, with no compliance at all like poly bushings. If you are using real polyurathane bushings on a 914, then they would probably work much better than the plastic ones do. I am real happy with the Elephant bushings, but real poly may work fine, and needle bearings might be even better. Dunno. Just hate the plastic ones.
- Lo-Fi Version Time is now: 12th March 2026 - 12:37 PM
