> Alternate tire size = fail inspection??!!??, State of Maine
BCinSC
post Dec 8 2005, 07:46 AM
Nothing but Trouble
Sorry: NPC - '95 Lexus ES300, but I know y'all will give excellent advice
Want to put 195/65 R15 on instead of 205/65 R15 and am told that car will fail Maine inspection because it has anti-lock brakes and those 12mm in circumference difference will negate effectiveness?
Demick
post Dec 8 2005, 09:55 AM
Ernie made me do it!
Keep this in mind. New 195/65's will be about the same diameter as worn out 205/65's. That's how small the difference is. And tires also vary from mfg to mfg. So it is more than likely that a different brand of 205/65's could vary in diameter even more than the theoritical difference between 195 and 205.
Can't imagine it could cause any sort of problem as long as you change all 4.
Of course, whether or not it causes a problem has nothing to do with whether or not you will pass inspection. If 'correct size' tires is a checklist item for the inspection and you don't have the 'correct size', you will fail.
Demick
BCinSC   Alternate tire size = fail inspection??!!??   Dec 8 2005, 07:46 AM
ArtechnikA   914's do not have antilock brakes...   Dec 8 2005, 07:48 AM
BCinSC   Is THAT why I almost rear-ended that semi on I-95 ...   Dec 8 2005, 07:52 AM
rick 918-S   You could move to another state like MN. We don...   Dec 8 2005, 08:02 AM
ArtechnikA   i'll be following this thread... i plan to mo...   Dec 8 2005, 08:02 AM
BCinSC   I could certainly see issue with AWD or Anti-Lock ...   Dec 8 2005, 08:38 AM
groot   ABS will not care what wheel size you use, as long...   Dec 8 2005, 08:52 AM
rhcb914   I don't see it being a problem. I put 195 sno...   Dec 8 2005, 09:01 AM
SLKWrx   I can vouch that in NJ you will not fail inspectio...   Dec 8 2005, 09:04 AM
groot     Dec 8 2005, 09:44 AM
Demick   Keep this in mind. New 195/65's will be about...   Dec 8 2005, 09:55 AM
bd1308     Dec 8 2005, 12:02 PM
Crazyhippy     Dec 9 2005, 12:01 AM
djm914-6   People are missing the point. THIS IS MAINE! T...   Dec 9 2005, 07:22 AM
groot     Dec 9 2005, 04:11 PM
djm914-6   Thanks Rich. I was wondering why my 225-50-16 tire...   Dec 9 2005, 05:59 PM
groot     Dec 10 2005, 09:18 AM
Brett W   Being that your car is a 95 I would not worry abou...   Dec 10 2005, 09:44 AM
BCinSC     Dec 11 2005, 10:54 AM
groot   Yep, it happens more often than it should, unfortu...   Dec 11 2005, 11:13 AM
Brett W   When you combine heavy vehicles, with soft suspens...   Dec 11 2005, 01:14 PM
BCinSC   http://www.914world.com/bbs2/htm...   Dec 12 2005, 06:38 PM
groot   Dude, you asked.   Dec 13 2005, 08:48 AM
- Lo-Fi Version Time is now: 6th July 2025 - 04:18 PM
