> Alternate tire size = fail inspection??!!??, State of Maine
BCinSC
post Dec 8 2005, 07:46 AM
Nothing but Trouble
Sorry: NPC - '95 Lexus ES300, but I know y'all will give excellent advice
Want to put 195/65 R15 on instead of 205/65 R15 and am told that car will fail Maine inspection because it has anti-lock brakes and those 12mm in circumference difference will negate effectiveness?
groot
post Dec 10 2005, 09:18 AM
Dis member
QUOTE (Pnambic @ Dec 9 2005, 12:05 PM)
Also, while it is true that the cars are tested extensively on the tires they leave the factory with, I would be very surprised if the tire choice is not heavily influenced by whatever deal the tire manufacturers are willing to cut the car manufacturer. I'm sure they have an idea of what class tire they want, and then find a good deal on a tire in that class. There are lots of ratings for tires (noise/load/speed/weather/etc) to take into consideration when selecting a new set, but I don't at all feel obligated by loyalty or safety to stick with the OEM tires.
While this is true, it's a bit more complicated than that. See, the tire manufacturers make deals with the OEMs, and submit up to 10 different tires for the OEMs to test. And they're always a compromise. While tires can be built to focus on different attributes, you really can only get 2 of those attributes since the attributes work against each other (fuel economy and NVH, or snow and wet handling, steering precision and NVH, etc). So, you look for the best mix and tune around the tire.
Picking a tire with slightly more grip on a passenger car can lead to a debead or rim strike in an emergency situation. We tested a competitive vehicle last week that debeaded it's right rear tire during the tire warm-up session. Scary stuff. So, the point is not all OEMs are as thorough as we are.
BCinSC   Alternate tire size = fail inspection??!!??   Dec 8 2005, 07:46 AM
ArtechnikA   914's do not have antilock brakes...   Dec 8 2005, 07:48 AM
BCinSC   Is THAT why I almost rear-ended that semi on I-95 ...   Dec 8 2005, 07:52 AM
rick 918-S   You could move to another state like MN. We don...   Dec 8 2005, 08:02 AM
ArtechnikA   i'll be following this thread... i plan to mo...   Dec 8 2005, 08:02 AM
BCinSC   I could certainly see issue with AWD or Anti-Lock ...   Dec 8 2005, 08:38 AM
groot   ABS will not care what wheel size you use, as long...   Dec 8 2005, 08:52 AM
rhcb914   I don't see it being a problem. I put 195 sno...   Dec 8 2005, 09:01 AM
SLKWrx   I can vouch that in NJ you will not fail inspectio...   Dec 8 2005, 09:04 AM
groot     Dec 8 2005, 09:44 AM
Demick   Keep this in mind. New 195/65's will be about...   Dec 8 2005, 09:55 AM
bd1308     Dec 8 2005, 12:02 PM
Crazyhippy     Dec 9 2005, 12:01 AM
djm914-6   People are missing the point. THIS IS MAINE! T...   Dec 9 2005, 07:22 AM
groot     Dec 9 2005, 04:11 PM
djm914-6   Thanks Rich. I was wondering why my 225-50-16 tire...   Dec 9 2005, 05:59 PM
groot     Dec 10 2005, 09:18 AM
Brett W   Being that your car is a 95 I would not worry abou...   Dec 10 2005, 09:44 AM
BCinSC     Dec 11 2005, 10:54 AM
groot   Yep, it happens more often than it should, unfortu...   Dec 11 2005, 11:13 AM
Brett W   When you combine heavy vehicles, with soft suspens...   Dec 11 2005, 01:14 PM
BCinSC   http://www.914world.com/bbs2/htm...   Dec 12 2005, 06:38 PM
groot   Dude, you asked.   Dec 13 2005, 08:48 AM
- Lo-Fi Version Time is now: 6th July 2025 - 01:58 PM
