Loud Knock - Very Scared, Need Help Immediately |
Nor.Cal.914 |
Dec 8 2005, 06:30 PM
1975 914 3.0SC Group: Members Posts: 1,050 Joined: 28-January 05 From: Weatherford, TX Member No.: 3,523 Region Association: None |
I was just driving my car a minute ago and something very bad just happened. I had a concern about my revs earlier and how it wouldn't let me go over 4000 rpm. Well, I just replaced the coil and was trying it out to see if it helped my revs go past 4000. When I took it up there, something happened and a very loud knocking noise started happening. Another person on this thread had a post about a loud knocking noise that he heard when he started his car. Mine seems to be making the same kind of noise. I need help immediately! Any help as soon as possible would be helpful, please. Thank you very much.
-Chris |
brp914 |
Dec 10 2005, 02:39 PM
Unregistered |
YIKES - STOP - dont take off those heat exchangers. Asking for big trouble. If its too late and you've stripped the stud out of the head, there is unused thread further up in the head, but you have to get a longer stud. That will buy you some time. Otherwise, trying to put in a helicoil with the engine installed can be done, but is easy to mess up, in which case your head may be toast. If the engines is coming out anyway, have all those studs checked/replaced. It would be a heart breaker to rebuild the engine, install it, strip the studs out, and then have to remove and dismantle the engine again. 914 heads are made of mushy alloy.
Lo-Fi Version | Time is now: 6th June 2024 - 06:27 PM |
