dmilzoff |
Member ![]() ![]() Group: Members Posts: 67 Joined: 2-March 03 From: Ossining, NY Member No.: 377 ![]() |
Am I getting too fanatical or is this a real problem?
On my 914-6, I have 911 brakes up front and original rear brakes. I found the right rear brake dragging (smoking!). After opeining the vent clearance and oiling the emergency brake linkage, I took the car out for a 4 mile ride. Rotor temperatures using a infrared temp probe was Left Front 145 deg. F. Right Front 150 Left Rear 180 Right Rear 225 Question 1: Shouldn't the front rotors be hotter? Should I remove the brake proportioning valve or replace it with a new one to correct this? Question 2: Is the right rear too hot for such a short ride? |
dmilzoff |
Correction. I forgot that the brake lines were replaced with SS years ago. I guess a Tee and caliper rebuild is in order.
You guys don't make this easy. |
Lo-Fi Version | Time is now: 16th June 2024 - 09:55 AM |
