Sway bars, factory or no factory? |
rjames |
Dec 16 2005, 03:55 PM
I'm made of metal Group: Members Posts: 3,949 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Found factory NOS sway bars for sale, both front and rear. From what I've read so far from other postings, installing the rear sway bar won't have a huge noticable effect, (unless installed without the front.
Is this true? ...and secondly, should I go with a factory sway bar, or find an aftermarket one? I'm not concerned about weight, just improving the handling. Any opinions? |
Dave_Darling |
Dec 16 2005, 05:47 PM
Having both is fine--I liked the way my car drove with both stock bars hooked up better than when I disconnected the rear bar. However, you need to weld in the mounts for the rear one. That's a bit of hassle for what is frankly not a large gain.
You can increase the roll stiffness of the rear end of the car by going with stiffer springs. That's easier than swapping in a bar, and works just as well under almost all circumstances. I like being able to adjust the oversteer/understeer balance of the car using the adjustable sway bar, so I prefer the aftermarket bars to the stockers. But any front sway bar is definitely better than none!! --DD |
Lo-Fi Version | Time is now: 3rd June 2024 - 06:54 AM |
