l-jet problems |
l-jet problems |
driver_37_kart |
Dec 17 2005, 04:37 PM
Newbie Group: Members Posts: 6 Joined: 23-October 05 From: colfax, ca Member No.: 4,986 |
heres the problem, i was driving along running fine, until my negative battery terminal came loose off the wire, which then everything died on the car. i shoved the wire back in (i had no tools with me) and went for another mile or so until the wire fell off again, but this time when i hooked it back up it didn't start. (i don't know if the ground wire story has anything to do with my problem or if it is pure coincidental)
so where i am now is, it has spark and fuel in the rails. it starts off the cold start valve until it runs out of fuel and then it dies. i pulled off the terminals to the injectors and put a test light to it and it pulsates but the pulses appear to fade after it starts up. so its almost like the resistor block isn't energizing (i've never heard of one going out) so thats where i am now. everyone tells me to leave the fuel injection on but i'm sure losing me patience and money over it. |
driver_37_kart |
Dec 17 2005, 05:43 PM
i replaced the dual relay and the fuel pressure is at 35psi the injectors work and i switched out the air flow meter with no different results. i just find it odd that it sends power to the injectors.
Lo-Fi Version | Time is now: 9th June 2024 - 02:27 AM |
