l-jet problems |
l-jet problems |
driver_37_kart |
Dec 17 2005, 04:37 PM
Newbie Group: Members Posts: 6 Joined: 23-October 05 From: colfax, ca Member No.: 4,986 |
heres the problem, i was driving along running fine, until my negative battery terminal came loose off the wire, which then everything died on the car. i shoved the wire back in (i had no tools with me) and went for another mile or so until the wire fell off again, but this time when i hooked it back up it didn't start. (i don't know if the ground wire story has anything to do with my problem or if it is pure coincidental)
so where i am now is, it has spark and fuel in the rails. it starts off the cold start valve until it runs out of fuel and then it dies. i pulled off the terminals to the injectors and put a test light to it and it pulsates but the pulses appear to fade after it starts up. so its almost like the resistor block isn't energizing (i've never heard of one going out) so thats where i am now. everyone tells me to leave the fuel injection on but i'm sure losing me patience and money over it. |
ClayPerrine |
Dec 18 2005, 08:53 AM
Life's been good to me so far..... Group: Admin Posts: 15,519 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
FYI.... You can remove ALL the relays on the relay board on an L-Jet injected 914 and it will still run fine. The L-Jet system uses NONE of those relays. Did you check the pulse on the injector when it is cranking or running? There are different ways to engage the double relay when its cranking vs when its running. |
Lo-Fi Version | Time is now: 9th June 2024 - 11:17 AM |
