| fiid |
Jul 31 2003, 09:43 AM
Turbo Megasquirted Subaru Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,828 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
Hey all,
I have obtained a Subaru EJ20DETT motor that I intend to put in my 914. For those not familiar with this motor - here is some info: Water cooled flat 4 - twin turbos- staged. 276hp, 252.98 lbft torque The engine also has coil-over-plugs. (i.e. there is a small coil mounted over each spark plug). My plans fror the project are: Use Ron Simpson Radiator, and some sheet metal that allows me to retain use of the front trunk. Spare tire in rear trunk. Rebuild 901 box with billet intermediate plate, side cover, and limited slip. Mount engine to tranny using KEP adapter. Fabricate engine mount and exhaust (I'm thinkin 2 glasspacks should do it). Here are the questions: How do I get the thing to fire (anyone know of projects or products that can drive 4 coils and no distributer)??? Any better solutions to the transmition question? Should I run a 915? What do you guys think? I have uprated the suspension to 23mm front sway bars with weltbushings, konis all round and 180lb rear springs. I intend to put bmw front calipers on it and it has a 19mm front master cyl. Opinions? Ideas? I think this thing is going to rock when it's done! Fiid. (IMG:style_emoticons/default/aktion035.gif) |
| Malmz |
Aug 25 2003, 09:52 AM
CSOBOSC founding member ![]() ![]() Group: Benefactors Posts: 489 Joined: 22-April 03 From: So. Cal Member No.: 602 |
QUOTE(jonwatts @ Aug 24 2003, 10:39 PM) The intake is symmetrical. You can spin the whole thing around 180 degrees and have the throttle body pointing towards the front of the car instead of the rear. Same for the exhaust but that complicates turbo placement. THAT is good news. Interesting. Did you take any measurements of how far it will hang off the front of the motor, and or look at if you could put a 90 degree turn in before the intercooler? IMHO, the radiator has to be in the front of the car to get proper airflow to cool the beast. Those with lower hp conversions (less then 200hp) may be able to get away with dual radiators in the engine compartment. I would use a side vent near the engine compartment to feed the intercooler. sm |
fiid Subaru EJ20DETT Transplant Jul 31 2003, 09:43 AM
aufaber It's been done a few times now, there are also... Jul 31 2003, 10:12 AM
Mueller There are a few Subaru powered 914's running a... Jul 31 2003, 10:29 AM
Brad Roberts Mike..
You have met Fiid 3-4 times at Roadglue ev... Jul 31 2003, 11:13 AM
Brad Roberts Oh.. if you have the money... shoot for the 915 bo... Jul 31 2003, 11:15 AM
aufaber And if you've got the money for a 915, then yo... Jul 31 2003, 12:17 PM
fiid The thing I like about the Rod Simpson radiator is... Jul 31 2003, 12:18 PM
fiid <... Jul 31 2003, 12:21 PM
airsix For the 911 suspension you can just use the 911 st... Jul 31 2003, 12:39 PM
Hawktel What if you added side scoops, hung 2 radiators in... Jul 31 2003, 12:43 PM
redshift I haven't driven a 915 converted 914 in a whil... Jul 31 2003, 01:45 PM
fiid <... Jul 31 2003, 02:17 PM
fiid
redshift The rears can be drilled for about $100.00, a... Jul 31 2003, 02:25 PM
fiid Another question.....
I have a lightened flywheel... Jul 31 2003, 02:27 PM
airsix Regarding 911 struts and 5-lug rear hubs:
When I s... Jul 31 2003, 03:06 PM
soloracer Sounds like a fun project. If you plan on keeping... Jul 31 2003, 06:09 PM
fiid
jonwatts
fiid ... Aug 25 2003, 09:37 AM
fiid Jon Watts - where are you???? :-) Time to talk pr... Sep 22 2003, 03:24 PM
fiid Oh yeah- does anyone know where I can get a wiring... Sep 22 2003, 03:25 PM
cha914 I don't know if you have seen these forums yet... Sep 22 2003, 08:21 PM
jonwatts ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:22 PM |
