Question for those runnning a Wevo 915....., ......Yeah, both of you! |
East coaster |
Dec 19 2005, 05:05 PM
Senior Member Group: Members Posts: 1,691 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None |
So I know not many are running Wevo 915s, but somebody must have gone down the same road as me. I have a '74 914 (obviously a side shift setup) that will be receiving a 3.6/Wevo 915 conversion and a 915 style (Rennshift) shift lever. The 915 style shift lever has a cup type bushing on it and the side shift linkage is a bolt on arrangement (read: round peg in a square hole). What are you guys using for the shift rod through the tunnel? I assume either an early tail shifter rod or 911 rod??
I figured on fabbing the rod and joints from the firewall back, but thought I could get away with a stock piece in the tunnel, is that not true? **If the answer is old tail shifter rod, anybody got one laying around? (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
rick 918-S |
Dec 19 2005, 05:21 PM
Hey nice rack! -Celette Group: Members Posts: 20,489 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I don't have a 915 but I used the early shifter with the ball and cup (early shifter and linkage) including the swivel joint at the firewall, and the rear shift rod for the tail shift. I cut the rear section and added the side shift end to the rear rod.
I needed the oil pan clearance. The swivel joint moved the linkage over just enough to clear the pan. |
Lo-Fi Version | Time is now: 8th June 2024 - 03:23 AM |
