Timing help |
Timing help |
r_towle |
Dec 19 2005, 01:15 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Ok,
stock 1.8 liter ljet. The book says timing is 7.5 BDTC at 900 rpms... I cant get there... I can get close, but the engine dies if I set it right on. The dwell is perfect, the vacuum lines are all new. It just wants to die if I get it close...so right now I am advanced a bit , it idles perfect and revs fine (have yet to drive it to see if it detonates...) I messed with the idle screw while doing it to keep it running... I need help trying to diagnos why it will not allow me to time it correctly...yes the single vacuum line was disconnected from the dizzy and plugged. there are two connections at the dizzy, but only one on the throttle body, one is for advance and one for retard...the retard is not hooked up, no place to plug it in..I know that is the way they came... Rich |
Joe Ricard |
Dec 20 2005, 10:10 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Stick a chop stick in there. if it goes through when the car is warm that is bad.
Chopsticks may be substituded for anything that won't break or get stuck. OK really engine cold the valve should be opened. as the engine warms the valve will close no air flow. this can be checked with engine running and hose pulled off the AAR valve. |
Lo-Fi Version | Time is now: 3rd June 2024 - 08:37 AM |
