Hot starting problems.... on a 914/6 |
914_6conv |
Aug 25 2003, 05:53 PM
Newbie Group: Members Posts: 7 Joined: 25-August 03 From: sorel-tracy, quebec Member No.: 1,075 |
Hi, new to the list but not to 914s. My problem is that whenever i try to restart the engine after a short stop, lets say a fuel fill-up, it just doesnt. It cranks, but does not fire. After a while, 5-10 minutes, it does. No problem on cold start, it fires right away. I suspect bad coil, misbehaves when hot. But once started, it runs fine. any clue? My set up: Blue coil, Permatune, Pressure regulator, webers on a 2.2E engine with S-cams. Thanks to all.
dmilzoff |
Aug 25 2003, 05:59 PM
Member Group: Members Posts: 67 Joined: 2-March 03 From: Ossining, NY Member No.: 377 |
I had same problem with mine. This is a common problem. Check or replace the ground wire between the engine and body. Check for rust or paint under the ground wire where it bolts to the body. To test, bring battery cables with you and, when you are having the problem, connect one end to the engine and one end to the body and try to start the engine.
Lo-Fi Version | Time is now: 16th June 2024 - 07:38 AM |
