> Fuel Hose and linkage Routing for dual carbs, Show me your setup
Carlitos Way
post Dec 20 2005, 12:10 PM
I did it MY WAY
Looking for dual carb fuel setups. Would love to see type/routing of fuel lines, how you ran them, how you set up your linkage, where you installed your fuel pump, filter and regulator (if any).
Thanks!
Aaron Cox
post Dec 21 2005, 12:14 PM
Professional Lawn Dart
QUOTE (Carlitos Way @ Dec 21 2005, 11:11 AM)
QUOTE (Kargeek @ Dec 21 2005, 09:37 AM)
Having the arms to the rear is no big deal... you set it up properly once and that's it. More time is spent adjusting fuel mixture and synchronizing both carbs... then adjust your drop links to fit with the throttle arms horizontal without any side to side preloading of your final carb set up.
It also makes for neatly routing the stock length throttle cable.
Yes, the arms are centered with springs in each end of the bar.
The only issue with arms to the rear is if you have a tall mount linkage - it may interfere with the trunk torsion bars- mine are gone as I’m using 944 rear hatch shocks.
DH
Where did you get that mounting bracket for the throttle cable? That is AWESOME!!!
he made it.
looks like 18ga, a little dremel, and a set of vice grips to fold it, and a drill...
Carlitos Way   Fuel Hose and linkage Routing for dual carbs   Dec 20 2005, 12:10 PM
Aaron Cox   http://www.914world.com/bbs2/uploads/blog-11116237...   Dec 20 2005, 12:13 PM
Joe Ricard   Tank, prefilter, pump, fuel line through tunnel, c...   Dec 20 2005, 12:17 PM
brant   sorry If I sound like a broken record... but I sti...   Dec 20 2005, 12:32 PM
maf914   Ditto on the two fuel line setups as described abo...   Dec 20 2005, 12:35 PM
Aaron Cox     Dec 20 2005, 12:39 PM
brant   This picture is the new car (old car was the carbe...   Dec 20 2005, 12:43 PM
Aaron Cox   also - a search for carb linkage yielded 3 pages o...   Dec 20 2005, 01:08 PM
maf914     Dec 20 2005, 10:17 PM
URY914   Here is a picture of my -16. MUCH better....   Dec 20 2005, 10:19 PM
Aaron Cox     Dec 20 2005, 10:20 PM
maf914   Wow, I can't believe the flat 12 in Paul's...   Dec 21 2005, 08:06 AM
rhodyguy   best linkage on the market in my book. expensive? ...   Dec 21 2005, 09:45 AM
jr91472   Thanks for starting this thread. I am in the same...   Dec 21 2005, 10:07 AM
rhodyguy   forgot to add mine is a triad. i never understood ...   Dec 21 2005, 10:10 AM
Carlitos Way   I really dig this linkage:   Dec 21 2005, 10:18 AM
rhodyguy   look are where the drop links are positioned in th...   Dec 21 2005, 10:29 AM
Aaron Cox   ...   Dec 21 2005, 10:53 AM
Kargeek   Having the arms to the rear is no big deal... you ...   Dec 21 2005, 11:37 AM
Carlitos Way   <...   Dec 21 2005, 12:11 PM
Aaron Cox   http://www....   Dec 23 2005, 10:16 PM
trekkor   zoiks http://www.914world.com/bbs2/...   Dec 23 2005, 10:21 PM
Aaron Cox   <...   Dec 23 2005, 10:22 PM
brant   couple of things... were not talking fuel injecti...   Dec 23 2005, 10:25 PM
Eddie Williams   Either way I think it's a good discussion. My...   Dec 24 2005, 12:25 AM
synthesisdv   here's my rig, the IDF's need 3lb or less ...   Dec 24 2005, 07:29 AM
- Lo-Fi Version Time is now: 11th July 2025 - 07:05 AM
