GT oil system, bunch of pics of my approximation |
michel richard |
Dec 27 2005, 11:45 AM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
As part of my GT look alike project, I spent quite a bit of time on the oil system. Here's the link to the overall project thread:
http://www.914world.com/bbs2/index.php?act=...=ST&f=2&t=34896 There's several good threads on the site about coolers. I started one, soliciting opinions about a possible oil cooler to use. I must say I had not done a search before starting that thread. If I had, I would have found a lot of the information I was looking for. see: http://www.914world.com/bbs2/index.php?act=...=0entry529632 I've decided to move away from the solution I was exploring there, which involved Porsche 928 transmission oil coolers and instead to use an Rx7 cooler that I will modify and then have ultrasound cleaned. Actually, all the parts below will need a super-thorough cleaning before the engine starts, to avoid contamination. There's a place in town that does ultrasound cleaning, and that appears to be the best route. I have also started a thread on the hard oil lines, and tub modifications to make room for those. See: http://www.914world.com/bbs2/index.php?act=...=0entry529632 I have'nt sourced the hard oil lines yet. In any event, I've done a lot of work on assembling a GT style oil system for my car. Here's an overall view of the part of the system in the engine compartment: |
michel richard |
Dec 27 2005, 11:56 AM
Finally: I have yet to test the pressure at which it opens, it should be around 80 psi. If I'm off a little, I can adjust it. I used the fittings from a junk engine case that still had them.
Attached image(s) |
Lo-Fi Version | Time is now: 8th June 2024 - 01:16 PM |
