bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
so i get a flickering glowing light (gen light) and is this possible to change out with the engine in the car? i get *NO* usability from this alternator.
or can i fix it? b |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
With everything in place, does the light illuminate when you turn on the key? Have you cleaned and checked the fuses? Does the light extinguish when you start the car and exceed 1500 RPM? Are you measuring the voltage across the battery posts? If you're checking it by the gauge, you're asking for trouble. It measures the voltage at or near the fusebox, and is notoriously "eye candy". If you decide (after answering these questions), buy a voltage regulator first. Get a real Bosch one; the others don't work, more often than not. If that doesn't solve the problem, get a genuine Bosch reman alternator. Mind the length of the post on the back. It can short out against the rear cover. The Cap'n
Lo-Fi Version | Time is now: 15th July 2025 - 01:10 PM |
