> alternator dead, sigh...
bd1308
post Dec 30 2005, 01:46 PM
Sir Post-a-lot
so i get a flickering glowing light (gen light) and is this possible to change out with the engine in the car? i get *NO* usability from this alternator.
or can i fix it?
b
r_towle
post Dec 30 2005, 06:05 PM
Custom Member
for an engineering student, you jump to conclusions way to quickly....
You need to be more methodical...
It is cheaper to be methodical...
Lets review....
Your alternator was ok before you changed the wiring and added new crap to the relay board...right
It was ok and working before you took out the voltage regulator to remove the cover to the relay board, right...
If it was me, and I am cheap, I would be cleaning and re-seating all those cables, and make sure to apply pressure to the bottom of the relay board while you are pushing down so you dont break something else....
Check your alternator correctly.
bypass and check your voltage regulator (I vote for dirty contacts and not seated correctly)
Check your voltage output at the battery while at 2500 rpms STEADY, not blipped.
Fill your battery with new water, and charge it fully with a battery charger before jumping into a new alternator.
Be thorough, its cheaper.
Rule out everything you did first, since this problem happened (HHMMM New Ljet FI wiring...)
Rich
bd1308   alternator dead   Dec 30 2005, 01:46 PM
McMark   The alternator can be changed with the motor in th...   Dec 30 2005, 01:55 PM
JOHNMAN   I am very sorry to hear that your alternator is ba...   Dec 30 2005, 01:55 PM
lapuwali   Plugging the alternator harness directly into the ...   Dec 30 2005, 02:02 PM
Mueller   as long as the windings are not open (good chance ...   Dec 30 2005, 02:02 PM
bd1308   really strange. so i plug the VR into the alterna...   Dec 30 2005, 02:21 PM
bd1308   well...i think this alternator is toast. Let me tr...   Dec 30 2005, 02:30 PM
Mueller     Dec 30 2005, 02:58 PM
Cap'n Krusty   With everything in place, does the light illuminat...   Dec 30 2005, 03:01 PM
rhodyguy   britt, is this going on (the light) at idle and on...   Dec 30 2005, 03:21 PM
r_towle   for an engineering student, you jump to conclusion...   Dec 30 2005, 06:05 PM
lapuwali   If you plug the VR directly into the alternator ha...   Dec 30 2005, 09:44 PM
JOHNMAN     Dec 30 2005, 10:01 PM
bd1308   okay. I was thinking about this while I was drivin...   Dec 30 2005, 11:15 PM
SLITS   3 wires to the starter: One from battery One fro...   Dec 30 2005, 11:38 PM
bd1308   teh light flickers, intermittent connection. If i ...   Dec 30 2005, 11:49 PM
Tom Perso   Glad you didn't buy an alternator? LOL Engin...   Dec 31 2005, 07:02 AM
davep   Also check the ground leads from the tranny to the...   Dec 31 2005, 07:12 AM
bd1308   already done friend. right now, the battery lug ...   Dec 31 2005, 08:38 AM
bd1308   well this thing is getting really out of hand. I ...   Dec 31 2005, 09:41 AM
- Lo-Fi Version Time is now: 15th July 2025 - 01:27 PM
