> Marv's 3.6 GT project thread, the journey
Marv's3.6six
post Nov 17 2005, 12:08 AM
Actual member 7"
I have always loved the 914/6 GT's and will be converting this orig 6 (below) to an updated GT plus try to build a TTOD capable AX’r. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
It will be pretty much be a straight up racer, no heat, no radio, no nuthin, almost a full GT car but with no roll cage. To get to TTOD I felt that I needed a few things I did not already have, such as more rubber beneath me, more low end torque, closer gear ratios, LS diff, more tuneable suspension, body stiffening, yadda yadda, you get the drift.
This first pic is when I bought her in August 02, she's a factory six with a 3.2 and 915 trans, 911s suspension, was PCASDR 99 & 2000 AX champ for class HI.
Marv's3.6six
post Jan 8 2006, 09:31 AM
Actual member 7"
No not thru the tunnel. Running along the outside GT style, but where most peeps go in the cab & around the pedals I did not want the lines inside. So I went up and inside the left front wheel well then thru the bulkhead panel where the radio antennae wire goes in, then down by the fuel cell, following the wiring harness.
Marv's3.6six   Marv's 3.6 GT project thread   Nov 17 2005, 12:08 AM
Andyrew   Ya need slicks for TTOD.... buuut... Cool stuff...   Nov 17 2005, 02:37 AM
DrifterJay   Marv! A teener guy in Murrieta!! Cool...   Nov 17 2005, 05:29 PM
Rand   http://www.9...   Dec 22 2005, 09:38 PM
Rob Ways   http://www.914world.com/bbs2...   Dec 22 2005, 10:35 PM
Eddie Williams   Very Nice. http://www.914...   Dec 22 2005, 10:42 PM
trekkor   I love seeing a project coming together. Way to m...   Dec 22 2005, 11:45 PM
Lou W   Looks Great. http://www.914w...   Dec 23 2005, 12:08 AM
Marv's3.6six   Sound deadning for undercoat. Forgot to look at br...   Dec 23 2005, 08:09 PM
Marv's3.6six   12/23 Center tunnel wiring loom finished. Tunnel p...   Dec 23 2005, 08:10 PM
Aaron Cox   marv - title changed http://www.91...   Dec 23 2005, 08:52 PM
jim912928   You are doing one unbelievable job!   Dec 23 2005, 08:56 PM
Marv's3.6six     Dec 23 2005, 09:07 PM
Markeydoo   Marv That looks GREAT. When will it be complete?? ...   Dec 24 2005, 02:52 PM
Marv's3.6six
  Dec 24 2005, 03:55 PM
Markeydoo   Cool The pictures look GREAT. Once I get a few mor...   Dec 30 2005, 10:37 PM
Marv's3.6six   12/31/2005 Got some good work done, cut several ho...   Jan 1 2006, 02:15 PM
Aaron Cox   the bracket things look like the ones on the rear ...   Jan 1 2006, 02:20 PM
Marv's3.6six   1/7/06 Bulkhead fittings and -12 45AN fittings tes...   Jan 8 2006, 08:44 AM
Marv's3.6six   1/7/06 Inside wheel well. -12 bulkheads and AN 90...   Jan 8 2006, 08:46 AM
Marv's3.6six   1/7/06 Time to make a big hole.   Jan 8 2006, 08:47 AM
Marv's3.6six   1/7/06 The biggest cut I have done on a teener 9X1...   Jan 8 2006, 08:50 AM
Marv's3.6six   1/7/06 Mount oil cooler to custom fab rubber mount...   Jan 8 2006, 08:54 AM
Marv's3.6six   1/7/06 fab custom -12AN lines from oil cooler to T...   Jan 8 2006, 08:57 AM
Marv's3.6six   1/07/06 Passenger side mono ball.   Jan 8 2006, 08:59 AM
Marv's3.6six   1/7/06 Bilstein RSR drop spindle strut mounted to ...   Jan 8 2006, 09:03 AM
Marv's3.6six   1/7/06 Tom's thumb   Jan 8 2006, 09:04 AM
Marv's3.6six   1/7/06 Carbon fiber air deflector test fit. It d...   Jan 8 2006, 09:06 AM
East coaster   Marv........Looks killer! Are you running you...   Jan 8 2006, 09:24 AM
Marv's3.6six   No not thru the tunnel. Running along the outside ...   Jan 8 2006, 09:31 AM
Luke M   Keep up the good work Marv. Keep us posted on the ...   Jan 8 2006, 11:58 AM
hars914   I ran my lines the same way. It was way better tha...   Jan 9 2006, 02:13 PM
Lou W   Sure is looking good, keep the pictures coming. in...   Jan 9 2006, 02:42 PM
Luke M   Hey, Marv Question on your wire harness. Is it new...   Jan 9 2006, 10:03 PM
Markeydoo   Looks Good Marv. Is the fuel cell going where the ...   Jan 9 2006, 10:13 PM
Marv's3.6six
  Jan 9 2006, 11:56 PM
Marv's3.6six   1/11/06 Oil lines finished in front trunk, top vie...   Jan 12 2006, 08:09 AM
Marv's3.6six   01/11/06 Oil lines lower view, to Tstat.   Jan 12 2006, 08:10 AM
Marv's3.6six   01/11/06 23mm Brake master cylinder install.   Jan 12 2006, 08:11 AM
Eric Taylor   God this project is sexy, I love reading the threa...   Jan 12 2006, 11:54 AM
Aaron Cox   marv, any worries about the hot oil lines runnin...   Jan 12 2006, 12:00 PM
Marv's3.6six
  Jan 12 2006, 02:44 PM
Aaron Cox   http://www.914world.com/bbs2/html/e...   Jan 12 2006, 03:57 PM
Marv's3.6six   1/21/06 Battery mount   Jan 29 2006, 09:39 AM
Marv's3.6six   1/21/06 Changed my mind and decided to mount the r...   Jan 29 2006, 09:41 AM
Marv's3.6six   1/21/06 Grinded out existing holes for oil lines t...   Jan 29 2006, 09:43 AM
Marv's3.6six   1/25/06 Brake fluid rese mounted, hood hinges moun...   Jan 29 2006, 11:04 AM
Marv's3.6six   1/25/06 rear wheel test fit. Gonna have them refin...   Jan 29 2006, 11:08 AM
jim912928   the rims...have them match the exterior paint sche...   Jan 29 2006, 11:10 AM
Marv's3.6six   1/28/06 Front wheel test fit. The wheel looks pret...   Jan 29 2006, 11:13 AM
Marv's3.6six   1/28/06 suspension installed, brake hard lines ins...   Jan 29 2006, 11:15 AM
Marv's3.6six   1/28/06 Brake bias valve installed.   Jan 29 2006, 11:34 AM
fiid   I think this is the cleanest project I've ever...   Jan 29 2006, 12:44 PM
brp914   seems like an odd place for the thermostat. the p...   Jan 29 2006, 02:03 PM
J P Stein     Jan 29 2006, 05:25 PM
trekkor   Here's mine. I've seen one mounted behind ...   Jan 29 2006, 06:19 PM
grasshopper   wow!!! your car is looking great!...   Jan 29 2006, 06:21 PM
Marv's3.6six   1/29/06 Fabricating lower valence, ABS spoiler.   Jan 29 2006, 08:16 PM
Marv's3.6six   1/29/06 Lower valence with spoiler, front view.   Jan 29 2006, 08:18 PM
Marv's3.6six   1/29/06 Side view. http://www.914wo...   Jan 29 2006, 08:20 PM
nein14   Looks Great!!!!! close attenti...   Jan 29 2006, 08:25 PM
Jeroen   nice! Is that a regular GT front valence? Or s...   Jan 29 2006, 11:08 PM
Marv's3.6six
  Jan 30 2006, 12:07 AM
markb   Absolutely beautiful. http:/...   Jan 30 2006, 01:06 AM
Van914   Marv, Love the front valance and spoiler. Too bad ...   Jan 30 2006, 05:54 AM
Racing916   Marv any thought of fabricating front valances and...   Jan 30 2006, 06:52 AM
Gint   Beauty! Hey, what are you putting along the b...   Jan 30 2006, 08:38 AM
Lou W   That will be one gorgeous car
  Jan 30 2006, 11:39 PM
5 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 27th November 2026 - 03:20 AM
