> Weltmeister Rear Sway Bar, looking for pcs and tips
hmeeder
post Jan 5 2006, 02:40 PM
Dante's Sportscar
I received a Weltmeister Rear Sway Bar as a donation to my track car project.
It's a used unit and as such has no instructions/templates for the install. Anyone have any pics of theirs in the car and tips to make sure I don't dick it up?
A test fit shows that it may interfere with the shocks at the full-soft setting. Both ends of the bar contact at the adjustable mount. There doesn't seem to be that much room for travel either, though I can shorten the droplinks by about 3/4 inch or so (unless the bar is supposed to ride below the lower shock mount? Seems unlikely, but that's why I'm asking the question, eh?)
A search only gave me a photo of a stock set up which doesn't help. The mounting points are different, but the bar is in the correct position above the lower shock mount.
Many TIA!
campbellcj
post Jan 8 2006, 12:52 PM
I can't Re Member
QUOTE (Luke M @ Jan 8 2006, 10:40 AM)
Couldnt you shorten the drop link for more clearance?
I havent installed mine yet but just a thought.
Yup, you can. On mine virtually none of the threaded portion is visible. IIRC you want to try to adjust the droplinks to get the ends of the bar as close to parallel to the ground as feasible.
There's evidence on my car of the drop link hitting the trunk floor at some time in its life (with the PO) but I have never noticed this happen since my ownership - I substantially stiffened up the suspension & chassis.
I keep it on full soft but prefer the way the car behaves with it vs. without it. Having front + rear bars also gives you quite a bit of trackside fine-tuning capabilities without having to dick around with spring swapping.
hmeeder   Weltmeister Rear Sway Bar   Jan 5 2006, 02:40 PM
Aaron Cox   i know jim hoyland has a welt rear bar.... http://www.914world.com/bbs2/...   Jan 5 2006, 05:00 PM
ottox914   I'm on the road and have no axcess to take pho...   Jan 5 2006, 06:22 PM
drew365   I have a Welt bar on the rear of my car. It is set...   Jan 5 2006, 08:20 PM
hmeeder   Well, I got it figured out. The installation was ...   Jan 8 2006, 11:34 AM
Luke M   Couldnt you shorten the drop link for more clearan...   Jan 8 2006, 12:40 PM
campbellcj     Jan 8 2006, 12:52 PM
Travis Neff   Can you point the droplinks back instead of up? t...   Jan 8 2006, 12:57 PM
brant   just a few more pictures. Like Chris, we shortened...   Jan 8 2006, 01:07 PM
brant   We used aluminum shims to give it a bit more rotat...   Jan 8 2006, 01:09 PM
brant   Here is our attatchment.. and in this picture the ...   Jan 8 2006, 01:13 PM
Andyrew   Where did you guys get the shock mounting bolt? Di...   Jan 8 2006, 01:27 PM
campbellcj   I just scanned the installation instructions. My g...   Jan 8 2006, 01:27 PM
914bub   I just scanned the installation instructions. My ...   Jun 10 2015, 07:03 PM
campbellcj   Hate to dredge up a seriously old thread but I...   Jun 10 2015, 08:07 PM
campbellcj   [quote name='914bub' post='2197369' date='Jun 10 ...   Jun 10 2015, 11:03 PM
hmeeder   Chris and Brant; Thanks Gentlemen (?) that's ...   Jan 8 2006, 01:42 PM
campbellcj   Actually I think you do have it installed per the ...   Jan 8 2006, 01:48 PM
hmeeder   Thanks Chris; A closer read of your instructions ...   Jan 8 2006, 02:06 PM
brant   our springs... and specifically spring hats create...   Jan 8 2006, 02:15 PM
campbellcj   I might also note that I grew to dislike the Weltm...   Jun 10 2015, 08:09 PM
- Lo-Fi Version Time is now: 30th April 2026 - 04:20 AM
