DIY "hot tank" works great !!!!!, Solvent recommendations ??? |
Mueller |
Aug 29 2003, 12:00 PM
Sorry no pics, maybe this weekend I'll shoot some.........
anyways............. I needed to strip some tar, undercoating and paint off of some of my suspension parts as well as engine parts and decided to make my own hot tank. I used a large plastic tub, filled it with a 50/50 mix Castrol SuperClean and hot water (boiled the water on my oven and dumped it into the tub with the parts in it) Within a few hours, the parts had been completly stripped of all paint and undercoating. Much easier than sandblasting to remove the paint and all the other crud. I think my next step will be to add an electric heating element to the tub....it looks like an heating element for a electric water heater would work out perfect...the element is about 12 dollars and the thermostat is about 25 dollars or so. I have yet to clean anything aluminum with this setup since I know the Castrol SuperClean really attacks the aluminum if left in the solution too long, but I'm sure it'll work out nice as long as I keep an eye out on the time the parts are left in the solution. What other solvents would be ideal in a "hot tank"??? |
Brad Roberts |
Aug 29 2003, 12:03 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
heating element in a plastic tub ?? How would you keep it from melting the area that supports or passes thru the tub wall ?? Or would you just dip it in ??
B |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:09 PM |
