L-jet Q, cams... |
L-jet Q, cams... |
bd1308 |
Jan 10 2006, 11:13 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
912E engines were 2.0 914 engines with L-jet fitted to them. Intresting point that someone brought up was the fact that the engine was fitted with a carb cam....at first thought, I was like huh?
but it kinda makes sense....the whole reason that carb cams couldnt work with D-jet was because the vaccuum signals at idle weren't what the mps wanted or was looking for...so the idle was rough to say the least (a pure guess). So, in L-jet you have this intresting change....an air flow meter, designed to match the amount of air entering the plenum with the "correct" amount of gasoline, which is running a tad rich--due to the displacement difference. But it doesnt matter how choppy the vac signal is, as long as the engine draws in air, the AFM will know and will give the air some fuel to mix..... so my Question: could a carb cam be used in a L-jet system for a little extra pep? 1.7L 72 engine. It's late, so if im way off, just lemme know. b |
bd1308 |
Jan 11 2006, 08:10 AM
I like being the underdog....I guess.
L-jet is great. My engine is great. I'm just wondering what cam the 2.0 912E engine had in it....somebody said a warm cam and then it made me think, thats all. b |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:51 PM |
