DIY "hot tank" works great !!!!!, Solvent recommendations ??? |
Mueller |
Aug 29 2003, 12:00 PM
Sorry no pics, maybe this weekend I'll shoot some.........
anyways............. I needed to strip some tar, undercoating and paint off of some of my suspension parts as well as engine parts and decided to make my own hot tank. I used a large plastic tub, filled it with a 50/50 mix Castrol SuperClean and hot water (boiled the water on my oven and dumped it into the tub with the parts in it) Within a few hours, the parts had been completly stripped of all paint and undercoating. Much easier than sandblasting to remove the paint and all the other crud. I think my next step will be to add an electric heating element to the tub....it looks like an heating element for a electric water heater would work out perfect...the element is about 12 dollars and the thermostat is about 25 dollars or so. I have yet to clean anything aluminum with this setup since I know the Castrol SuperClean really attacks the aluminum if left in the solution too long, but I'm sure it'll work out nice as long as I keep an eye out on the time the parts are left in the solution. What other solvents would be ideal in a "hot tank"??? |
3D914 |
Aug 29 2003, 12:12 PM
Unregistered |
Mueller,
Just curious. What happens to the "solvent" when you're done. Is it stored to use again (probably not), or if displosed of - where, how? TIA (IMG:style_emoticons/default/boldblue.gif) , |
Lo-Fi Version | Time is now: 12th June 2024 - 04:22 PM |
