static set, timing |
toon1 |
Jan 12 2006, 03:22 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
I set the timing staticly by using the timing mark on the fan(it's red on mine) not the zero. alighned it with the notch in the fan housing and then turned the dist to alighn the rotor with the mark on the top of the dist. case.
Will this get me close? |
alpha434 |
Jan 12 2006, 03:30 PM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
Yeah. Gets you really close.
Next comes the easy part. Start the car, work the gas with one foot, while you reach around and loosen the distributer so that you can freely turn it. Let the gas drop to idle and twist the distributer until it sounds really good. In my opinion, this is better than a timing light, sinces it sets it right to your engine and not right to the engineer's specs- which don't account for data variations from one unit to the next. (IMG:http://www.914world.com/bbs2/html/emoticons/ninja.gif) If this is the ninja- then the other one MUST be a terrorist!!! |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:08 PM |
