bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
I rearranged the LT1 wiring harness to terminate at a plug with all the connections I need for the engine. This plug plugs into the 18 pin socket on the side of the box. Below that is an 8 pin socket for the trans (starter, reverse lights, trans cooler pump).
Attached image(s) ![]() |
bondo |
On the other side is a power connector where the major current loads go in and out of the box. Above that is a socket for signal connections. (gauges, serial data, check engine light, etc.)
Lo-Fi Version | Time is now: 3rd July 2025 - 05:53 PM |
