> Valve adjust, How often do you do it?
Yoei66
post Jan 14 2006, 12:33 PM
My ride
I've put about 4000 miles on my 1.8 since I purchased & had the valves adjusted. Is it about time for another? How often do you adjust the valves on your 914-4's?
ThinAir
post Jan 14 2006, 02:11 PM
Best friends
Every 3,000 miles without fail. That got drilled into me back in 1979 when I first got into VW maintenance and I've stuck by it. If VW or Porsche ever recommended anything else, I've never seen it. Now that I run synthetic oil I've changed the oil change interval to 6,000 miles, but the valves still get checked every 3,000 miles. There is so much that depends upon proper valve adjustment that I want to make sure they never out of adjustment.
Yoei66   Valve adjust   Jan 14 2006, 12:33 PM
Headrage   IIRC the recommended interval from Porsche is ever...   Jan 14 2006, 12:44 PM
ThinAir914   Every 3,000 miles without fail. That got drilled ...   Jan 14 2006, 02:11 PM
Dave_Darling   I change my oil every 3000 miles, and check the va...   Jan 14 2006, 02:46 PM
bd1308   6k, unless something odd happens. b   Jan 14 2006, 02:54 PM
redshift   I do exactly the same as Dave does, plus whenever ...   Jan 14 2006, 05:34 PM
type47   can we now revisit the discussion about valve lash...   Jan 14 2006, 06:00 PM
Bleyseng   Every other AX or track event since I really don...   Jan 14 2006, 08:12 PM
Headrage   ...   Jan 14 2006, 08:47 PM
Joe Ricard   I'm with Geoff, Hate the job but I run the ...   Jan 15 2006, 10:20 AM
Bleyseng   ...   Jan 15 2006, 10:45 AM
hedfurst   Chrome-moly pushrods, zero lash. Makes the adjustm...   Jan 15 2006, 11:29 AM
dmenche914   keep a record of the before and after cleanence. ...   Jan 15 2006, 11:32 AM
mikelsr
- Lo-Fi Version Time is now: 22nd September 2025 - 10:32 PM
