> HEADLIGHT MOTOR, REMOVAL
TINCAN914
post Jan 14 2006, 04:08 PM
Summer's Commin...
Ok I was looking through the Haynes manual, and I'm not seeing a great deal of detail, looked here and couldn't find it in the search, so here we go.
I have pulled the headlight motor, but I still have the wires attached to it. They appear to be soldered on, with one red terminal connecting to it as well. There is also what appears to be what would resemble a fuse connector for lack of a better term (1"x2" plastic clip) with the wires running through both sides. How do I disconnect the motor from the wires?
I'm sure I don't have to cut them, and I can't figure out how to seperate the wire clip.
Sorry no pics digital camera is not available....
Does this make any sense?
boxstr
post Jan 14 2006, 04:56 PM
Use a very small,very thin flat tip screwdriver and push it down into the plastic connector,there are tabs that hold the brass terminals inside the connector. You have to push them in so that they can then seperate and slide out of the plastic connector.
CCLINLIGHTMYWAY
bmunday   HEADLIGHT MOTOR   Jan 14 2006, 04:08 PM
black73   I think the connector stays with the motor. Pull t...   Jan 14 2006, 04:23 PM
lapuwali   Hm. Perhaps this is a year to year variation, bu...   Jan 14 2006, 04:36 PM
boxstr   Use a very small,very thin flat tip screwdriver an...   Jan 14 2006, 04:56 PM
bmunday   Thanks guy's, will give it a shot...   Jan 14 2006, 05:52 PM
Headrage   <...   Jan 14 2006, 06:43 PM
bmunday   Oh man it was simple.. I just didn't want to s...   Jan 14 2006, 11:04 PM
- Lo-Fi Version Time is now: 19th July 2025 - 10:25 AM
