> Lotta fun with Megasquirt, Autotune, tunes while you drive
DNHunt
post Jan 14 2006, 08:24 AM
914 Wizard? No way. I got too much to learn.
I downloaded a newer version of Megasquirt with autotune. It uses a wideband O2 meter to adjust the air fuel mixture to a target while you drive. The targets vary according to RPM and manifold vacuum. I have a high of 14 at cruise and a low of 12.6 at WOT. Megasquit keeps adjusting until the amount of fuel gives the desired voltage from the O2 meter. It speeds up tuning a ton. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
It's cool to see it changing without any key strokes on the computer. There are a couple things to consider (there always are). Tuning is only as good as the O2 meter and the air fuel mixture is just a number pulled out of the air. It will not tune the ignition side of the ECU. So, when I get everything sorted out and the engine well broken in it still goes on a dyno.
Dave
airsix
post Jan 14 2006, 08:02 PM
I have bees in my epiglotis
QUOTE (DNHunt @ Jan 14 2006, 08:25 AM)
The auto tune is pretty slick. It's tough to use it at high RPM and low vacuum cause you just don't linger there for very long...
Dave, that's what big brakes are for. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Second gear, hard on the gas, hard on the brakes. Ease it up from 30 to 50mph and you got it. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
-Ben M.
DNHunt   Lotta fun with Megasquirt   Jan 14 2006, 08:24 AM
nsyr   Sounds great. i have ms2 v3 that i will be using i...   Jan 14 2006, 09:06 AM
Tom Perso   Hey Dave, Nice to hear that - I upgraded the firm...   Jan 14 2006, 10:01 AM
DNHunt   Andrew Play with it on the stim first to see how ...   Jan 14 2006, 10:25 AM
bd1308   so what if you dont have any data for the high RPM...   Jan 14 2006, 10:33 AM
DNHunt   Britt Autotune will tune it BUT, I quess I'm ...   Jan 14 2006, 10:56 AM
Hydra   I've just received my MSI v3, i'm right in...   Jan 14 2006, 11:44 AM
lapuwali   I'd use something with less teeth than 36-1. ...   Jan 14 2006, 01:51 PM
DNHunt   The MS 1 8-bit processor is full to the gills. The...   Jan 14 2006, 07:09 PM
airsix     Jan 14 2006, 08:02 PM
fiid   I'm still using MSTweak for my tuning. From w...   Jan 14 2006, 08:30 PM
yarin     Jan 14 2006, 11:36 PM
lapuwali   Actually, you probably don't want to use MSII ...   Jan 15 2006, 12:59 AM
Tom Perso   I'm still up in the air with my ignition trigg...   Jan 15 2006, 06:49 AM
DNHunt   The system I'm using is really working well, b...   Jan 15 2006, 07:41 AM
stock93   Dave, Thanks for the post. I always like to hear a...   Jan 15 2006, 09:44 AM
crash914   I am still waiting for my MS2 chip....I guess I co...   Jan 15 2006, 03:56 PM
Rocky   Dave, heard and saw you buzzin Hwy 16 yesterday an...   Jan 15 2006, 08:04 PM
Gary   Some pretty cool stuff going on over in the megasq...   Jan 15 2006, 09:53 PM
DNHunt   Hey Rocky good to hear from you. I've been ter...   Jan 16 2006, 08:32 AM
yarin   Wow.. those guys are certainly cranking out some a...   Jan 16 2006, 08:42 AM
Hydra   this topic is getting more interesting by the minu...   Jan 16 2006, 09:00 AM
DNHunt   Yarin I wish I could help you but, I'm runnin...   Jan 16 2006, 09:09 AM
yarin   Thanks for the response Dave. I posted my question...   Jan 16 2006, 03:09 PM
yarin   I learned a hell of a lot from this post regarding...   Jan 16 2006, 03:39 PM
Rocky   Yea Dave, we do need to get together. I work way ...   Jan 16 2006, 09:42 PM
- Lo-Fi Version Time is now: 10th June 2026 - 06:20 PM
