| DNHunt |
Jan 14 2006, 08:24 AM
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
I downloaded a newer version of Megasquirt with autotune. It uses a wideband O2 meter to adjust the air fuel mixture to a target while you drive. The targets vary according to RPM and manifold vacuum. I have a high of 14 at cruise and a low of 12.6 at WOT. Megasquit keeps adjusting until the amount of fuel gives the desired voltage from the O2 meter. It speeds up tuning a ton. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
It's cool to see it changing without any key strokes on the computer. There are a couple things to consider (there always are). Tuning is only as good as the O2 meter and the air fuel mixture is just a number pulled out of the air. It will not tune the ignition side of the ECU. So, when I get everything sorted out and the engine well broken in it still goes on a dyno. Dave |
| DNHunt |
Jan 15 2006, 07:41 AM
The system I'm using is really working well, but I want to switch to the new chip to get more resolution in pulsewidth. That could pay some real dividends as the A/F mixture will steady out. Most people can't tell that it jumps around some with the MSI but, I can. MSII also offers a more sophisticated closed loop fuel control. MSII on the version 3 board will do what I am doing now with MSI but I want to let the more adventurous work the bugs out.
I would like to do COP eventually just because it can be done. Some weekend this winter I'll put the V3 board together and get MSII running on the stim in preparation for the code version I will want to run. I know that second wheel support is in the works with a version of code a couple of releases from now and the router board is being tested now. I'm stuck with my 36-1 wheel since it's was part of the rotating mass Jake balanced (I've learned you don't mess with Jake's balance). So, whatever I do will involve a 36-1 and VR sensor. Of course that's not all bad because there will always be support for that configuration. I'm kind of looking at a Vanagon distibutor for the second wheel. I believe they are an optical sensor and fit right in. Otherwise, I think I have a dizzy with a pertronix in it. I look over the MSEFI web site everyday and it is still hard to keep up. It's a rare day when there isn't some change to something. It's amazing what people are doing and since the MSII code is in C I expect it will develop farther. Being a more robust processor than MSI it has more onboard potential. Add to that CAN and slaving more boards and who knows what's up. Time to start learning C Dave |
DNHunt Lotta fun with Megasquirt Jan 14 2006, 08:24 AM
nsyr Sounds great. i have ms2 v3 that i will be using i... Jan 14 2006, 09:06 AM
Tom Perso Hey Dave,
Nice to hear that - I upgraded the firm... Jan 14 2006, 10:01 AM
DNHunt Andrew
Play with it on the stim first to see how ... Jan 14 2006, 10:25 AM
bd1308 so what if you dont have any data for the high RPM... Jan 14 2006, 10:33 AM
DNHunt Britt
Autotune will tune it BUT, I quess I'm ... Jan 14 2006, 10:56 AM
Hydra I've just received my MSI v3, i'm right in... Jan 14 2006, 11:44 AM
lapuwali I'd use something with less teeth than 36-1. ... Jan 14 2006, 01:51 PM
DNHunt The MS 1 8-bit processor is full to the gills. The... Jan 14 2006, 07:09 PM
airsix Jan 14 2006, 08:02 PM
fiid I'm still using MSTweak for my tuning. From w... Jan 14 2006, 08:30 PM
yarin Jan 14 2006, 11:36 PM
lapuwali Actually, you probably don't want to use MSII ... Jan 15 2006, 12:59 AM
Tom Perso I'm still up in the air with my ignition trigg... Jan 15 2006, 06:49 AM
stock93 Dave,
Thanks for the post. I always like to hear a... Jan 15 2006, 09:44 AM
crash914 I am still waiting for my MS2 chip....I guess I co... Jan 15 2006, 03:56 PM
Rocky Dave, heard and saw you buzzin Hwy 16 yesterday an... Jan 15 2006, 08:04 PM
Gary Some pretty cool stuff going on over in the megasq... Jan 15 2006, 09:53 PM
DNHunt Hey Rocky good to hear from you. I've been ter... Jan 16 2006, 08:32 AM
yarin Wow.. those guys are certainly cranking out some a... Jan 16 2006, 08:42 AM
Hydra this topic is getting more interesting by the minu... Jan 16 2006, 09:00 AM
DNHunt Yarin
I wish I could help you but, I'm runnin... Jan 16 2006, 09:09 AM
yarin Thanks for the response Dave. I posted my question... Jan 16 2006, 03:09 PM
yarin I learned a hell of a lot from this post regarding... Jan 16 2006, 03:39 PM
Rocky Yea Dave, we do need to get together. I work way ... Jan 16 2006, 09:42 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th June 2026 - 07:22 PM |
