| redshift |
Jan 13 2006, 12:03 PM
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
You say it won't start... it's turns over, just no combustion?
M |
| JoeSharp |
Jan 15 2006, 08:15 PM
In Irvine, Ca. May 15-18 ![]() ![]() ![]() ![]() Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
OH MY GOD.... That guy detailed the inside of the fan housing. Pull the engine cover, so you can get your head in there and look towrdes the back of the car part of your bike. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) You should see a notch, thats is the timing point on the fan housing. The timing marks are on the fan and it spins at the bottom of the notch. I have seen 2 notches 1 towrdes the front and one towrdes the rear. The rear one has the timing marks. There should be a 0 at top dead center (TDC) and as the crank turns there should be a mark at 27* before (I think) TDC. That is the timing mark for full advance.
If it has points put in an Igniter. :PRMAGRIN: Joe |
redshift Rambo's starting problem Jan 13 2006, 12:03 PM
SLITS Didn't feed it enough beans & hot sauce
http:... Jan 13 2006, 12:07 PM
ClayPerrine To make an internal combustion engine start and ru... Jan 13 2006, 12:31 PM
redshift If you have all that reliably, and you still get n... Jan 13 2006, 02:04 PM
Rambo The trick to remember is FAST!
It aint got a... Jan 14 2006, 07:50 PM
ThinAir914 Jan 14 2006, 11:53 PM
bd1308 http://www.914world.com/bbs2/html/e... Jan 15 2006, 08:15 PM
Rambo [CODE]
Jeff Bowlsby http://www.914world.com/bbs2/html/e... Jan 15 2006, 11:41 PM
Rambo Ok...how do I attach an image...I'll show you ... Jan 15 2006, 11:45 PM
Joe Sharp Dude: Sorry, I'm a 173rd vet and we can work i... Jan 15 2006, 11:48 PM
Joe Sharp Thanks Geoff.
:PERMAGRIN: Joe Jan 15 2006, 11:49 PM
Joe Sharp What time is it at where you are?
Good night.
:PER... Jan 15 2006, 11:53 PM
Rambo ok Brother....looking down from top of hole, I see... Jan 15 2006, 11:57 PM
Jeff Bowlsby A small hand mirror will give you visual access in... Jan 16 2006, 06:09 AM
gepetto143 Inside the distributor cap, there is a little "pin... Jan 16 2006, 06:35 AM
Rambo ok.aint got a small mirror, cut a Disk into strips... Jan 16 2006, 09:28 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 08:55 PM |
