> oil light?
sk8kat1
post Jan 15 2006, 05:40 PM
when I am stopped on a decline or if I comne to a hard stop the oil light flickers ?!
I chkd to see the oil is at the bottom narker ...
1) what oil is to be added to the car 5w 30 -- 10w40?
..... is there any thing else I should chk as well ?
Howard
post Jan 15 2006, 10:45 PM
Incontin(g)ent Member
Right. Just teasing you a bit. (IMG:http://www.914world.com/bbs2/html/emoticons/poke.gif) In engineering gibberish:
SAE 30 is SAE 30 no matter what the "W" prefix number is: 0W, 5W or 10W. This viscosity in centistokes (cSt) @ 100 degrees C is with the minimum of 9.3 cSt and a maximum of 12.5 cSt.
SAE defines 'normal' operating temperature in this case to be 100c or 212f. In order to have the SAE rating of 30, the oil must maintain that viscosity at that temp. The '10w' out front just means the viscosity at freezing is SAE 10. This allows the engine to better circulate lubricant at lower temps.
So 50 doesn't thin to 30. While 20w50 won't hurt, I still believe the 914 will benefit from lower viscosity oil. The benefits are cooler operating temps and less drag on the reciprocating parts. Just my 2 cents...
sk8kat1   oil light?   Jan 15 2006, 05:40 PM
Bleyseng   I like 20/50 wt for year around....5-30wt is too t...   Jan 15 2006, 06:49 PM
SGB   yes, 5w30 is too light, even in Illinois in Januar...   Jan 15 2006, 07:24 PM
Aaron Cox   green light means less than 10psi of oil pressure....   Jan 15 2006, 07:27 PM
Howard   Holy sheep shit. I agree with Aaron! I overf...   Jan 15 2006, 08:22 PM
Bleyseng   20/50wt is thick stuff to you???   Jan 15 2006, 09:21 PM
bd1308   20w-50 is real good...engine runs real sweet with ...   Jan 15 2006, 09:27 PM
Michael J   One other thing to check is if the wire is firmly ...   Jan 15 2006, 09:28 PM
bd1308   according to the porsche manual, a slight flicker ...   Jan 15 2006, 09:43 PM
Howard   ...   Jan 15 2006, 09:46 PM
Aaron Cox     Jan 15 2006, 09:48 PM
bd1308   yeah but i dont think they had multi-viscosity oil...   Jan 15 2006, 09:48 PM
Aaron Cox     Jan 15 2006, 09:51 PM
sk8kat1   ok 20-50 -- seems to be a good one -thanks.. <...   Jan 15 2006, 09:58 PM
bd1308   <...   Jan 15 2006, 10:08 PM
Howard   OK, quick test. With 20w50 oil, what does the ...   Jan 15 2006, 10:15 PM
bd1308   at 0 degrees C, water melts and at 100 it boils......   Jan 15 2006, 10:26 PM
Howard   Not a bad guess, but research and try again   Jan 15 2006, 10:34 PM
Howard   Right. Just teasing you a bit.   Jan 16 2006, 04:02 AM
dlo914     Jan 16 2006, 04:02 AM
Howard   Would really like to hear from the experts here. ...   Jan 16 2006, 09:54 AM
bd1308   i dont think i messed up. I think we were saying t...   Jan 16 2006, 10:41 AM
SLITS   Jeeeezzzzes....google it yourself.......... Mos...   Jan 16 2006, 11:20 AM
Howard   Ron, that was the link I posted ht...   Jan 16 2006, 11:53 AM
SLITS   The post was not aimed at you Howie......One of th...   Jan 16 2006, 12:53 PM
Howard   http://www.914world.com/bbs2/htm...   Jan 16 2006, 01:58 PM
bd1308   dont worry, soon i'll be here less...cant do s...   Jan 16 2006, 02:47 PM
SLITS   Britt....quit worrying. We're not ego centere...   Jan 16 2006, 03:13 PM
Howard   <...   Jan 16 2006, 04:52 PM
Mueller   back to the original posting http:/...   Jan 16 2006, 05:13 PM
reverie   Re multigrade oils - The lower viscosity is for ...   Jan 16 2006, 06:49 PM
Bleyseng   more info... "When the car was new, Porsche recom...   Jan 16 2006, 10:46 PM
- Lo-Fi Version Time is now: 15th July 2025 - 11:22 AM
