| DNHunt |
Jan 14 2006, 08:24 AM
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
I downloaded a newer version of Megasquirt with autotune. It uses a wideband O2 meter to adjust the air fuel mixture to a target while you drive. The targets vary according to RPM and manifold vacuum. I have a high of 14 at cruise and a low of 12.6 at WOT. Megasquit keeps adjusting until the amount of fuel gives the desired voltage from the O2 meter. It speeds up tuning a ton. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
It's cool to see it changing without any key strokes on the computer. There are a couple things to consider (there always are). Tuning is only as good as the O2 meter and the air fuel mixture is just a number pulled out of the air. It will not tune the ignition side of the ECU. So, when I get everything sorted out and the engine well broken in it still goes on a dyno. Dave |
| yarin |
Jan 16 2006, 08:42 AM
'14-X'in FOOL ![]() ![]() ![]() Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
Wow.. those guys are certainly cranking out some amazing additions to their lineup. The router board should be a neat addition allowing for more input and outputs.
Things us 914 people can do: External oil cooler flow control & temperature/pressure monitoring. Cold start fan block servo. i just came up with this one.. instead of using the original heat-expansion cold start block off it can be connected to a servo or solenoid. Fuel pressure info. Then again one of the reasons i found the 914 so attractive was its simplicity (no power anything, simple, light, to the point). Guys I have a question about my MS plan: How reliable / easy would it be to implement spark advance/timing control using MS II triggered from a Pertronix type optical or magnetic pickup on a stock dizzy. Can this signal be used to trigger MS? I've heard several people experience a noisy RPM signal coming from the negative side of the coil. Has anyone here run MS Ignition on a stock dizzy (advance locked) with a stock coil? Here is the page for using the high current driver: http://www.megasquirt.info/ms2/vb921.htm MS has a dwell parameter. Isn't the dwell set by either points or the slot in the optical pickup disc? Or does MS just read the first rise of the waveform and set its own duration? I found this potential problem on the MS site: "51. As we noted in step 50, there are two input circuits for the tach signal. One takes the square wave input from a hall sensor, optical sensor, or points. This is also used if you want to trigger off the negative side of the coil, since the points control the negative side of the coil's primary circuit. However, you can only trigger off the coil's negative terminal if you are NOT trying to control ignition timing. " located in here: http://www.megasquirt.info/ms2/V3assemble.htm Has anyone with a noisy tach input tried this? "If you are going to use the negative side of the coil to trigger MegaSquirt (I.e., you are not using ignition timing control), then install and solder C12, the Ed capacitor (399-2017-ND, 0.001 µF, 102 marking}. Otherwise leave the C12 location empty - DO NOT jumper it. This is located above "Bowling" in the copyright notice. The value of this capacitor may need to be increased if there are noise problems with the tach signal - values up to 0.1uf will work. The 0.001uf value is a good starting point." Thanks! I want to plan out my MS project and target any issues ahead of time before jumping into it. |
DNHunt Lotta fun with Megasquirt Jan 14 2006, 08:24 AM
nsyr Sounds great. i have ms2 v3 that i will be using i... Jan 14 2006, 09:06 AM
Tom Perso Hey Dave,
Nice to hear that - I upgraded the firm... Jan 14 2006, 10:01 AM
DNHunt Andrew
Play with it on the stim first to see how ... Jan 14 2006, 10:25 AM
bd1308 so what if you dont have any data for the high RPM... Jan 14 2006, 10:33 AM
DNHunt Britt
Autotune will tune it BUT, I quess I'm ... Jan 14 2006, 10:56 AM
Hydra I've just received my MSI v3, i'm right in... Jan 14 2006, 11:44 AM
lapuwali I'd use something with less teeth than 36-1. ... Jan 14 2006, 01:51 PM
DNHunt The MS 1 8-bit processor is full to the gills. The... Jan 14 2006, 07:09 PM
airsix Jan 14 2006, 08:02 PM
fiid I'm still using MSTweak for my tuning. From w... Jan 14 2006, 08:30 PM
yarin Jan 14 2006, 11:36 PM
lapuwali Actually, you probably don't want to use MSII ... Jan 15 2006, 12:59 AM
Tom Perso I'm still up in the air with my ignition trigg... Jan 15 2006, 06:49 AM
DNHunt The system I'm using is really working well, b... Jan 15 2006, 07:41 AM
stock93 Dave,
Thanks for the post. I always like to hear a... Jan 15 2006, 09:44 AM
crash914 I am still waiting for my MS2 chip....I guess I co... Jan 15 2006, 03:56 PM
Rocky Dave, heard and saw you buzzin Hwy 16 yesterday an... Jan 15 2006, 08:04 PM
Gary Some pretty cool stuff going on over in the megasq... Jan 15 2006, 09:53 PM
DNHunt Hey Rocky good to hear from you. I've been ter... Jan 16 2006, 08:32 AM
Hydra this topic is getting more interesting by the minu... Jan 16 2006, 09:00 AM
DNHunt Yarin
I wish I could help you but, I'm runnin... Jan 16 2006, 09:09 AM
yarin Thanks for the response Dave. I posted my question... Jan 16 2006, 03:09 PM
yarin I learned a hell of a lot from this post regarding... Jan 16 2006, 03:39 PM
Rocky Yea Dave, we do need to get together. I work way ... Jan 16 2006, 09:42 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th June 2026 - 06:19 PM |
