> Lotta fun with Megasquirt, Autotune, tunes while you drive
DNHunt
post Jan 14 2006, 08:24 AM
914 Wizard? No way. I got too much to learn.
I downloaded a newer version of Megasquirt with autotune. It uses a wideband O2 meter to adjust the air fuel mixture to a target while you drive. The targets vary according to RPM and manifold vacuum. I have a high of 14 at cruise and a low of 12.6 at WOT. Megasquit keeps adjusting until the amount of fuel gives the desired voltage from the O2 meter. It speeds up tuning a ton. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
It's cool to see it changing without any key strokes on the computer. There are a couple things to consider (there always are). Tuning is only as good as the O2 meter and the air fuel mixture is just a number pulled out of the air. It will not tune the ignition side of the ECU. So, when I get everything sorted out and the engine well broken in it still goes on a dyno.
Dave
DNHunt
post Jan 16 2006, 09:09 AM
Yarin
I wish I could help you but, I'm running EDIS now. I ran MS with fuel only and a Pertronix triggering a MSD 6A for a while. The tach imput came from the Pertronix if I remember and it was fine. Of course the dizy was contolling timing. I will have to look at my wiring diagram tonight.
Ask on the MS sight. There's always someone to help you.
Dave
DNHunt   Lotta fun with Megasquirt   Jan 14 2006, 08:24 AM
nsyr   Sounds great. i have ms2 v3 that i will be using i...   Jan 14 2006, 09:06 AM
Tom Perso   Hey Dave, Nice to hear that - I upgraded the firm...   Jan 14 2006, 10:01 AM
DNHunt   Andrew Play with it on the stim first to see how ...   Jan 14 2006, 10:25 AM
bd1308   so what if you dont have any data for the high RPM...   Jan 14 2006, 10:33 AM
DNHunt   Britt Autotune will tune it BUT, I quess I'm ...   Jan 14 2006, 10:56 AM
Hydra   I've just received my MSI v3, i'm right in...   Jan 14 2006, 11:44 AM
lapuwali   I'd use something with less teeth than 36-1. ...   Jan 14 2006, 01:51 PM
DNHunt   The MS 1 8-bit processor is full to the gills. The...   Jan 14 2006, 07:09 PM
airsix     Jan 14 2006, 08:02 PM
fiid   I'm still using MSTweak for my tuning. From w...   Jan 14 2006, 08:30 PM
yarin     Jan 14 2006, 11:36 PM
lapuwali   Actually, you probably don't want to use MSII ...   Jan 15 2006, 12:59 AM
Tom Perso   I'm still up in the air with my ignition trigg...   Jan 15 2006, 06:49 AM
DNHunt   The system I'm using is really working well, b...   Jan 15 2006, 07:41 AM
stock93   Dave, Thanks for the post. I always like to hear a...   Jan 15 2006, 09:44 AM
crash914   I am still waiting for my MS2 chip....I guess I co...   Jan 15 2006, 03:56 PM
Rocky   Dave, heard and saw you buzzin Hwy 16 yesterday an...   Jan 15 2006, 08:04 PM
Gary   Some pretty cool stuff going on over in the megasq...   Jan 15 2006, 09:53 PM
DNHunt   Hey Rocky good to hear from you. I've been ter...   Jan 16 2006, 08:32 AM
yarin   Wow.. those guys are certainly cranking out some a...   Jan 16 2006, 08:42 AM
Hydra   this topic is getting more interesting by the minu...   Jan 16 2006, 09:00 AM
DNHunt   Yarin I wish I could help you but, I'm runnin...   Jan 16 2006, 09:09 AM
yarin   Thanks for the response Dave. I posted my question...   Jan 16 2006, 03:09 PM
yarin   I learned a hell of a lot from this post regarding...   Jan 16 2006, 03:39 PM
Rocky   Yea Dave, we do need to get together. I work way ...   Jan 16 2006, 09:42 PM
- Lo-Fi Version Time is now: 10th June 2026 - 06:16 PM
