> No Fuel from Injectors, in crank mode
cary
post Jan 15 2006, 09:29 PM
We're still pulling our hair out. Took a perfectly running car. Pulled the engine to install a new muffler and straighten the front motor mount.
Now it won't start at times. Right now I have NO FUEL SPRAY from the injectors when we crank the ignition. It won't start like that. (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif)
Checked the valve adjustment, A-Ok.
Checked the ignition. All checked out, both HT & LT. We did have the ignition wire hooked to the (-) for a while.
But switching it back didn't help. Could that have burned up something I can't see ?
Fuel pressure perfect 29psi. Pumps 8 oz in 15 seconds.
Here's what I have now :
When you charge the ignition. One opposing pair of the injectors click. But a couple times. I got nothing. ZERO.
Then I unhook the harness to check the trigger points. I still get the click of the injectors with the harness unplugged. Is that right ?
So that leads me to test the harness to the ECU. All three (12, 21 & 22) test fine. Both continuity and signal. Still stumped. Tested the signal out of the trigger point connector. Fine on both sides.
Now I pull the injectors to test for spray. Nothing. I get a burst at the start. None during the cranking. Then a couple bursts when we turn the key off crank. That is screwed up. Pulled the plugs dry as a bone.
There has to be a simple answer. Its not that complex. But I'm missing something.
How come no spray at ignition crank ?
boxstr
post Jan 16 2006, 02:19 PM
The one on the left.
cary   No Fuel from Injectors, in crank mode   Jan 15 2006, 09:29 PM
boxstr   If your car has a bad injector resistor pack that ...   Jan 15 2006, 09:31 PM
bd1308   this is D-jet right? b   Jan 15 2006, 09:32 PM
cary   Sorry, 73 1.7 D-Jet. Craig, Where is it located ...   Jan 15 2006, 09:37 PM
bd1308   scratch the resistor pack comment. _Djet didnt ha...   Jan 15 2006, 09:40 PM
boxstr   Here is what one looks like. CCLINSHOWME   Jan 15 2006, 10:12 PM
boxstr   Okay never mind. CCLINOKAY   Jan 15 2006, 10:13 PM
bd1308     Jan 15 2006, 10:15 PM
cary   Beats the s*** out of me. Went back after dinner....   Jan 15 2006, 11:57 PM
cary   Well its a new day. Went out this am to start it. ...   Jan 16 2006, 08:39 AM
DNHunt   Cary A bad CHT will keep the car from starting bu...   Jan 16 2006, 08:55 AM
cary   Dave, your right. Backwards. The CHT would give ex...   Jan 16 2006, 11:06 AM
bd1308   maybe its time to get the harness rebuilt? b   Jan 16 2006, 11:11 AM
cary   I'm thinking the same thing. I was just away a...   Jan 16 2006, 11:18 AM
DNHunt   Wait a minute. I don't think i understood. Are...   Jan 16 2006, 11:56 AM
2-OH!   Broken wire/connection at the injector connector(s...   Jan 16 2006, 02:07 PM
dlo914     Jan 16 2006, 02:15 PM
dlo914     Jan 16 2006, 02:17 PM
boxstr   The one on the left.   Jan 16 2006, 02:19 PM
bd1308   dlo, this is what I owe you...i'm working on i...   Jan 16 2006, 02:43 PM
cary     Jan 16 2006, 02:47 PM
bd1308   how bout swapping in another brain? b   Jan 16 2006, 02:49 PM
cary   Went home for lunch. Super In Law had the dizzy ou...   Jan 16 2006, 03:02 PM
cary     Jan 16 2006, 03:03 PM
DNHunt   Explanation: Magic Smoke http://...   Jan 16 2006, 03:16 PM
DNHunt   I would imagine that the brain fires a priming pul...   Jan 16 2006, 03:20 PM
cary   I have to whole web site printed and in a three ri...   Jan 16 2006, 03:57 PM
cary   Update: Super In Law pulled the trigger points fr...   Jan 16 2006, 05:09 PM
cary   Okay it lives. Plus it has a bitch'n tune up. ...   Jan 16 2006, 11:17 PM
DNHunt   Good work you guys. I'm glad you have it up an...   Jan 17 2006, 07:39 AM
cary   Could have taken the top off yesterday. 35 degrees...   Jan 17 2006, 07:53 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:43 PM
