| 1973914 |
Jan 17 2006, 04:59 PM
Member ![]() ![]() Group: Members Posts: 353 Joined: 16-May 03 From: Washington, DC Member No.: 703 |
Motor is a 72 2.2 that has bumped out to a 2.5. It has an internal regulator. Can i use this without and external regulator or do i need to convert. The motor is carbed and there is no cicuit board in the car at all. MSD 6AL, Soft Touch Rev Controller, MSD Tach Adapter all already installed. Not sure how much of the wiring harness that came with the motor I need to save. (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif)
| Gary |
Jan 17 2006, 06:21 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 749 Joined: 12-January 03 From: Mount Airy, MD Member No.: 134 Region Association: MidAtlantic Region
You'll only need the relay board for circuits that need fuses and relays. On my six, I have an internally regulated alternator. I got rid of the relay board and wired up three generic bosch relays where the board used to be: 1 for the fuel pump, 1 for the heater fan, and 1 spare. Looks very tidy.
On the alternator, you should have three terminals: B+ goes to the starter or batter positive; ground goes to ground (duh), and DF (I think on mine it was labelled 61) goes to the generator dash light. The porsche tech bulletin on switching from an external to an internal regulator states some alterntators need a resistor put across the dash light to pull enough current to make the light go out. |
1973914 -6 alternator question HELP! Jan 17 2006, 04:59 PM
thesey914 as i understand if it has an internal reg then no ... Jan 17 2006, 05:14 PM
1973914 Well that would be a relief. Jan 17 2006, 05:27 PM
Root_Werks Yeah, internally regulated won't need the circ... Jan 17 2006, 05:29 PM
1973914 Thanks for the replies, this is exactly the kind o... Jan 17 2006, 09:10 PM
Gary Are you sure that's an internally regulated un... Jan 17 2006, 10:09 PM
914Sixer Alt looks like a early stock Bosch with no interna... Jan 18 2006, 08:40 AM
Root_Werks ... Jan 18 2006, 10:10 AM
Jeffs9146 Here is a photo of a non-regulated alt. Jan 18 2006, 02:38 PM
1973914 Well looks like I have to go external. Can i use ... Jan 18 2006, 06:09 PM
ClayPerrine <... Jan 18 2006, 06:34 PM
1973914 Is the more complex answer - Yes, but you will des... Jan 18 2006, 09:50 PM
Gary Nah, you should be fine. This diagram should help:... Jan 18 2006, 10:25 PM
r_towle http://www.914world.com/bbs2/h... Jan 18 2006, 10:46 PM
Porsche Rescue You have two choices. If you have your original re... Jan 19 2006, 12:10 AM
1973914 Thanks guys - appreciate you sticking through this... Jan 19 2006, 09:38 AM
Porsche Rescue I have a brown insulated wire, not a strap. Regard... Jan 19 2006, 09:53 AM
ClayPerrine ![]() ![]() |
Lo-Fi Version | Time is now: 4th July 2026 - 08:08 AM |
