bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
so okay...im in the process of putting everything back on that should be on...like head breather stuff and i'm on the crankcase breather right now.
i connect the piping all up, correct stuff with hose clamps. engine idles at like 250 and is obviously running like crap. I open the afm and push the flap more open and tada...it runs better. i do know I have a little more blow-by than I would like but I am very happy with this engine, and tearing it down isnt an option right now. so should I just vent the crankcase to atmosphere (which i REALLY dont like/want to do) or what? I have a new oil filler cap seal installed on it ( the ones from the samba group buy) it seems to fit in this channel thing on the cap istelf, but not at the very top of the cap. what do i do? b |
JWest |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,663 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None ![]() ![]() |
As in plugged or open? Also check your timing is correct and the vacuum advance/retard (I forget what is stock for 914 L-jet) is all hooked up and working properly. This must be set up just like stock to get the idle in the correct range without having to make other (off nominal) adjustments. |
Lo-Fi Version | Time is now: 1st August 2025 - 12:31 PM |
