> Front End Noise.., very, very low speed moan.
DougC
post Jan 18 2006, 02:26 PM
Hey I've noticed recently a moan as the car is bearly starting to move from a dead stop. It comes from the front end I think and I can almost since it through the steering wheel (as strange as that seems). The best way to discribe the noise is to say it sounds kind of like The Queen Mary or a large Ship leaving port (it's horn noise - but not near that load (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) ). I think people on the street could probably hear it - kind of embarrassing if I roll the car super slowly. I'm thinking maybe a slightly warped rotor but are there any common items to check for? This car has 911T front suspension and brakes btw. Also, this car sat for 3 years before I started driving it recently...but everything was supposedly renewed during a restoration (track prep) before it was stored for the 3 years, so maybe something has dried out a bit too much.
Doug C
Rand
post Jan 18 2006, 05:35 PM
Cross Member
If you only hear it below 5-10 mph, then I'm siding with wheel bearing.
But then again, the tone of the sound may be a clue: growl = bearing, moan = brakes... (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Does it change if you drag the brakes a little?
Jack it up and rotate the wheels while you listen.
DougC   Front End Noise..   Jan 18 2006, 02:26 PM
Aaron Cox   a warped rotor would "pulse", and not be a constan...   Jan 18 2006, 02:37 PM
DougC   Well, I'm thinking it is sort of a pulse, beca...   Jan 18 2006, 03:25 PM
SirAndy   wheel bearing .... http://www.914...   Jan 18 2006, 03:41 PM
r_towle   I would say its either brakes or bearings. both c...   Jan 18 2006, 03:43 PM
Eric_Shea   wheel bearing .... http://www.914...   Jan 18 2006, 04:39 PM
DougC   If it was a wheel bearing though, wouldn't I b...   Jan 18 2006, 05:00 PM
SirAndy     Jan 18 2006, 05:02 PM
Root_Werks   If it sounds almost "harmonic", it might be a cali...   Jan 18 2006, 05:21 PM
DougC   I'll check those things out guys - thanks. Dou...   Jan 18 2006, 05:33 PM
Rand   If you only hear it below 5-10 mph, then I'm s...   Jan 18 2006, 05:35 PM
lapuwali   The brake test isn't all that reliable. Wheel...   Jan 18 2006, 06:02 PM
Eric_Shea     Jan 18 2006, 06:06 PM
- Lo-Fi Version Time is now: 5th March 2026 - 11:37 AM
