> -6 alternator question HELP!
1973914
post Jan 17 2006, 04:59 PM
Motor is a 72 2.2 that has bumped out to a 2.5. It has an internal regulator. Can i use this without and external regulator or do i need to convert. The motor is carbed and there is no cicuit board in the car at all. MSD 6AL, Soft Touch Rev Controller, MSD Tach Adapter all already installed. Not sure how much of the wiring harness that came with the motor I need to save. (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif)
post Jan 19 2006, 09:38 AM
Thanks guys - appreciate you sticking through this with me. One last question" You say to ground to the chasis, but the copper strap that was attached is not overly long. What is the preffered method and location from the alternator and to the body?
1973914   -6 alternator question HELP!   Jan 17 2006, 04:59 PM
thesey914   as i understand if it has an internal reg then no ...   Jan 17 2006, 05:14 PM
1973914   Well that would be a relief.   Jan 17 2006, 05:27 PM
Root_Werks   Yeah, internally regulated won't need the circ...   Jan 17 2006, 05:29 PM
Gary   You'll only need the relay board for circuits ...   Jan 17 2006, 06:21 PM
1973914   Thanks for the replies, this is exactly the kind o...   Jan 17 2006, 09:10 PM
Gary   Are you sure that's an internally regulated un...   Jan 17 2006, 10:09 PM
914Sixer   Alt looks like a early stock Bosch with no interna...   Jan 18 2006, 08:40 AM
Root_Werks   ...   Jan 18 2006, 10:10 AM
Jeffs9146   Here is a photo of a non-regulated alt.   Jan 18 2006, 02:38 PM
1973914   Well looks like I have to go external. Can i use ...   Jan 18 2006, 06:09 PM
ClayPerrine   <...   Jan 18 2006, 06:34 PM
1973914   Is the more complex answer - Yes, but you will des...   Jan 18 2006, 09:50 PM
Gary   Nah, you should be fine. This diagram should help:...   Jan 18 2006, 10:25 PM
r_towle   http://www.914world.com/bbs2/h...   Jan 18 2006, 10:46 PM
Porsche Rescue   You have two choices. If you have your original re...   Jan 19 2006, 12:10 AM
1973914   Thanks guys - appreciate you sticking through this...   Jan 19 2006, 09:38 AM
Porsche Rescue   I have a brown insulated wire, not a strap. Regard...   Jan 19 2006, 09:53 AM
ClayPerrine
- Lo-Fi Version Time is now: 4th July 2026 - 08:08 AM
