> AFR at cruise vs head temps, and an oil leak ? too
agrump
post Jan 19 2006, 07:39 AM
I kind of freaked this morning because my head temps this morning were at 400f on #3, 380 on #1. After awhile I remembered that the gauge is calibrated for 70f so the real temp on #3 is around 365. I am still wondering if this is too high for just cruising on the hwy at 65-70 mph. I pulled the plugs the other day and 1,2 and 4 were tan with some deposits but #3 was white with just a very light coating. Going by the receipts I got with the car my engine is a 2056 running a 280 degree cam (Fat 442), 96 "euro" pistons with TS rings. I’m not sure about the static compression ratio but I did check with a gauge and found all the cylinders to be within 112-120 psi.
I’m currently running 13.7:1 afr, should I make it richer, say 13.0:1? The car use to have carbs and the afr was around 12.0:1 but I didn’t have my head temp gauge then.
One more thing, the motor runs strong but has a mysterious oil leak, doesn't leave puddles, does show any obvious signs of burning or dripping but the oil level drops significantly every once in a while. I had the head vent hose attached to the wrong nipple on the air cleaner so it may have been pulling a vacuum; I’m not sure if moving it has worked yet. Jake warns against using TS rings so I wonder if that could be the problem.
Thanks
mudfoot76
post Jan 19 2006, 09:51 AM
Currently teenerless :-(
Before my rebuild, my engine had TS rings. It had a voracious appetite for oil. Then after reading this board, and in particular Jake's insight on TS (I believe he said that really stands for Total Sh*t (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) ) I am thankful to no longer run them in my new motor. My oil level had hardly budged, and the oil doesn't foul after 100 miles either!
- Lo-Fi Version Time is now: 1st May 2026 - 12:37 AM
