| 1973914 |
Jan 17 2006, 04:59 PM
Member ![]() ![]() Group: Members Posts: 353 Joined: 16-May 03 From: Washington, DC Member No.: 703 |
Motor is a 72 2.2 that has bumped out to a 2.5. It has an internal regulator. Can i use this without and external regulator or do i need to convert. The motor is carbed and there is no cicuit board in the car at all. MSD 6AL, Soft Touch Rev Controller, MSD Tach Adapter all already installed. Not sure how much of the wiring harness that came with the motor I need to save. (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif)
| Porsche Rescue |
Jan 19 2006, 09:53 AM
Saving and Enjoying Old Porsches ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
I have a brown insulated wire, not a strap. Regardless, it attaches to one of the studs on the alternator body to which the plastic housing is attached. The other end goes under a nut on one of the studs at the top of the case just behind the alternator.
Then you have the large red to the starter solenoid. The red, green and brown go to the regulator. Also, a wire goes from the regulator to the "gen" light on the dash (shown as blue wire to K in the diagram linked above). |
1973914 -6 alternator question HELP! Jan 17 2006, 04:59 PM
thesey914 as i understand if it has an internal reg then no ... Jan 17 2006, 05:14 PM
1973914 Well that would be a relief. Jan 17 2006, 05:27 PM
Root_Werks Yeah, internally regulated won't need the circ... Jan 17 2006, 05:29 PM
Gary You'll only need the relay board for circuits ... Jan 17 2006, 06:21 PM
1973914 Thanks for the replies, this is exactly the kind o... Jan 17 2006, 09:10 PM
Gary Are you sure that's an internally regulated un... Jan 17 2006, 10:09 PM
914Sixer Alt looks like a early stock Bosch with no interna... Jan 18 2006, 08:40 AM
Root_Werks ... Jan 18 2006, 10:10 AM
Jeffs9146 Here is a photo of a non-regulated alt. Jan 18 2006, 02:38 PM
1973914 Well looks like I have to go external. Can i use ... Jan 18 2006, 06:09 PM
ClayPerrine <... Jan 18 2006, 06:34 PM
1973914 Is the more complex answer - Yes, but you will des... Jan 18 2006, 09:50 PM
Gary Nah, you should be fine. This diagram should help:... Jan 18 2006, 10:25 PM
r_towle http://www.914world.com/bbs2/h... Jan 18 2006, 10:46 PM
Porsche Rescue You have two choices. If you have your original re... Jan 19 2006, 12:10 AM
1973914 Thanks guys - appreciate you sticking through this... Jan 19 2006, 09:38 AM
ClayPerrine ![]() ![]() |
Lo-Fi Version | Time is now: 4th July 2026 - 08:08 AM |
