Engine cooling...Heads vrs Cylinders, what item is more of an impact ? |
Mueller |
Aug 30 2003, 10:21 AM
So what item?, the heads or the cylinders have more of an impact on engine performance and longevity when properly cooled?
If someone had a bolt-on kit for watercooling, would you rather have watercooled heads or watercooled cylinders? What temperature do the cylinders get to while the engine is working? |
airsix |
Aug 31 2003, 03:41 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
I look at it this way. Review Porsches history.
(over simplified) First they built engines with iron jugs and aluminum heads. This got them to little more than 40hp per cyl. (early six) Porsche has NEVER gotten huge power out of an engine with iron cyls. They don't shed heat. As HP increased the iron jugs were replaced by aluminum. This got them to as much as 75-100hp per cyl. (911turbo-917) To get past the 75-100hp/cyl. cooling limit they watercooled the heads (935-959) for upwards of 125hp/cyl. Then the 962 got watercooled heads AND cyls and could manage 125hp/cyl. and could do it for 24 hours straight. (this was all off the top of my head so correct me if there are any errors) So it seems to me that first you need aluminum jugs, then you need watercooled heads, then you need watercooled everything. -Ben M. |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:39 PM |
